Removing A/C system from '72 455
Old Mar 17, 2023 | 08:00 AM
jpilk99's Avatar
Hi All. I just bought a '72 Olds 98 with a 455. A fun project. It has Air Conditioning - the original one - and I want to remove it, or most of it, so that I can access brake lines and other parts. My question is: How do I this safely? I don't want to just "unbolt" everything and have the refrigerant leak out. I don't even know if there's still refrigerant in the system.
Thoughts? Thank you,
Jay
Old Mar 17, 2023 | 01:38 PM
442Harv's Avatar
Take it to a AC shop. They can empty it for you. Probably already leaked all out, if it hasn't been serviced in awhile.
Old Mar 17, 2023 | 01:45 PM
jpilk99's Avatar
Thank you. I think the car sat for 20 years. No belt on AC compressor. Is there a way to tell if there’s anything in it? A lot of the tune up work, and brake line replacement would be a lot easier if the compressor etc were outta the way.
Old Mar 17, 2023 | 02:07 PM
Remove the cap on the high pressure port and touch the schrader valve with a punch or similar tool briefly. Be sure to wear safety goggles. Either pressure comes out or it doesn't.
Old Mar 19, 2023 | 09:08 AM
jpilk99's Avatar
Can you still get these older AC systems "charged" and working? (Wondering if I should keep it and try to get it working).
Old Mar 19, 2023 | 10:05 AM
Sugar Bear's Avatar
Yes you definitely can get them working and working really well.
Old Mar 19, 2023 | 10:10 AM
^^x2^^
Old Mar 20, 2023 | 05:19 AM
If you remove the compressor, lines, condenser and evaporator make sure you keep everything in a box in case you decide later to reinstall it. R12 isn't super rare the way it was years ago. If you have it serviced make sure you put R12 back in it.
Old Mar 20, 2023 | 07:09 AM
Sugar Bear's Avatar
If the system is opened re-seal every opening. Don't leave any connections open.
72 Post
Aug 5, 2022 06:30 AM
72hardtop
Jun 6, 2017 07:48 PM
72allblackcoupe
Apr 7, 2014 07:52 AM
krashx7
Feb 6, 2013 02:00 PM
ZipTie
May 27, 2009 09:22 PM
