rear main leak
rear main leak
I have a 455 that is leaking at rear main, it has the dreaded rope seal. I've heard you could use a ford seal that is rubber and works perfectly. I don't know what size ford engine seal is used. Can someone please help.
Lugardo, check it out! ![EEK!](https://classicoldsmobile.com/forums/images/smilies/eek.gif)
https://classicoldsmobile.com/forums...main-seal.html
Apparently, you need a Ford 460 rear main seal. However, I guess there is extra machining that needs to be done to the crank to get it to work.
I have always used the Ford seal on a unmachined crank with no issues. Just whisper soothing words and lovingly polish your car after, hopefully it wont be too upset that you installed "brand X" parts!
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
FWIW, I didn't read much of the thread I provided a link to. You can always change to the Ford 460 rear main seal, but make sure you know that if you change then the guy with the red beard will surely know. There is no fooling that guy!
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
