Rally guage sensors
Old May 7, 2025 | 12:05 PM
Tegra1027's Avatar
Rally guage sensors
Hello. I am converting to rally gauges and I am struggling to be confident with where the new sensors are supposed to go. This is a 455 with A/C. Can anyone help? TIA!
Old May 7, 2025 | 01:53 PM
Remove the factory idiot light senders, and replace with the correct gauge sending units. They go in the same location.
There is a green wire on the ignition switch that technically needs to be removed from the connector. That will solve the “full hot when cranking” issue.
Old May 7, 2025 | 02:10 PM
Tegra1027's Avatar
My issue is that the sensors were not in the endine, so I just want to comfirm where they go.
Old May 7, 2025 | 02:49 PM
The oil pressure sensor goes on the ledge between the water pump and intake manifold and the temp sensor goes on the front of the intake manifold next to the waterneck.
Old May 7, 2025 | 02:52 PM
Tegra1027's Avatar
There is another port behind the oil fill tube. What goes there?
Old May 7, 2025 | 04:35 PM
svnt442's Avatar
There is nothing on the block near the oil fill tube.
This is a 350, but the oil gallery hole is on the same location.
So far as the coolant temp sender goes, it's usually in the drivers side coolant passage. The one on the passenger side is for the factory vacuum tree that is temperature controlled. It keeps the distributor from fully advancing unto the engine warms up.
The oil sender for the gauges will require an extension tube to clear the intake and timing cover. Make sure to use either teflon tape or liquid teflon to seal these or you will have oil leaks.
Old May 8, 2025 | 07:44 AM
Tegra1027's Avatar
Perfect! Thank you so much!
Old May 8, 2025 | 07:46 AM
Tegra1027's Avatar
Thank you!!!
BBLima
Feb 17, 2025 04:29 PM
Ontario69Hurst
Jul 22, 2021 05:49 PM
Bandit60
Jun 8, 2021 01:27 PM
kbdecatur
Jan 28, 2019 03:51 AM
neatolds
Aug 26, 2015 06:01 PM
