Oil Pump Bent?
Old May 8, 2025 | 01:35 PM
WTHIRTY1's Avatar
Escape From The Ordinary
Oil Pump Bent?
Is the pickup bent? Car was jacked up in the wrong spot using the oil pan and I fear it bent the pick up. I've tried both the Thornton OP+ pan plus an OEM 455 pan and it's hitting something in that area causing the holes on one side to not align. Thoughts?
Old May 8, 2025 | 02:03 PM
Oldsmaniac's Avatar
The pickup tube is just a friction fit into the oil pump. In the picture it is not sitting right, it should be almost level and not angled toward the crank or angled up to that degree. You should be able to move the tube and screen assembly back to level sitting just off the bottom of the oil pan sump.
Old May 8, 2025 | 04:15 PM
BillK's Avatar
The screen should be about 3/8" to 1/2" off the bottom of the pan with the gasket. I put a piece of modelling clay on the flat part of the screen and put the pan on and see how much it flattens the clay. You will have to tack weld or braze the pickup to the pump when done if it has been moved a bunch.
Old May 8, 2025 | 04:22 PM
BillK's Avatar
This is a 425 I did a couple of years ago. Not sure if this was the final position but its close.
rickw30
Sep 7, 2025 05:27 AM
rickw30
Sep 6, 2024 07:44 AM
72455442RA
Mar 22, 2022 09:09 AM
johnwrolds2018
Jan 11, 2022 04:36 PM
2blu442
Jan 26, 2018 02:57 PM
