Radiator hose '66 toronado
Old Feb 18, 2022 | 06:38 AM
'66toro's Avatar
Adding to my issues with replacing my radiator on my '66 Toronado is that I'm finding that the "lower" hose neck on my original radiator is 1 1/2" but new hoses are 1 3/4". I have had 2 new hoses now, the first one, a corrugated Dayco, was 1 3/4" and the 2nd hose, a continental elite molded hose, was also 1 3/4". The old one I took off was a corrugated hose and was also 1 3/4" and the neck had a small 3" section of 1 1/2" hose on to accommodate (take up the difference), of the bigger 1 3/4" old hose. My question now is, why are the new hoses larger at the neck end or is it that my original radiator, has been repaired at some time and a smaller lower neck added for some unknown reason?
Old Feb 18, 2022 | 06:49 AM
Manufacturers of replacement parts want to minimize costs so they can maximize profits. There is very little profit in parts for cars that are over half a century old, especially ones that are not popular to restore, so they try to make one P/N accommodate as many different applications as possible. In this case, a readily available bushing solves the diameter problem.
Old Feb 18, 2022 | 07:04 AM
'66toro's Avatar
Ok, great, so where can I get one of these bushings?,,,
Old Feb 18, 2022 | 07:09 AM
Type radiator hose bushing into Google.
Old Feb 18, 2022 | 01:15 PM
rocketraider's Avatar
Oldsdruid
Toronado lower hose diameters are different at radiator end between 66-69 and 70-77. Bushing is your best bet. It's a workaround and another leak point, but you do what you must.
You might also want to check with www.fusick.com and see if they can furnish a correct reproduction hose instead of fooling with that one-size-fits-none flex hose mess.
Old Feb 18, 2022 | 01:27 PM
'66toro's Avatar
Yes, the continental molded hose i got is of good quality but needs the bushing/reducer. Gates makes them but none of my local parts places, auto zone, advance, auto, NAPA, O'Reilly, etc. has it in stock, not a common asked-for item I would guess. but thanks to the dying mom and pop parts stores that are still in business, I found one that had it on the shelf and for a lesser price than the competitors online and I don't have to wait to get it shipped,,,
Loaded68W34's Avatar
The hoses (top and bottom) on my 68 are from fusick. No fitment issues.
Old Feb 18, 2022 | 01:33 PM
'66toro's Avatar
The top hose on my '66 Toronado is fine, both the radiator and the intake H2O fitting are the same at 1 1/2", I found it easy to buy that hose off the shelf at most parts stores,,,
Old Feb 18, 2022 | 04:29 PM
442Harv's Avatar
I have a 70 W30 car.Someone changed the water pump, and put on a 71 pump, which is the smaller hose, maybe someone put a different year pump on?
Tom442
Jun 12, 2017 05:51 PM
chip-powell
Apr 20, 2017 07:24 PM
CutLS
Non-Olds Engines
Mar 1, 2016 07:14 PM
OldsManNJ
Mar 23, 2011 08:47 AM
njot33
Feb 25, 2008 08:18 AM
