View Poll Results: How do I repair the Olds?
Buy a Summit/Jegs performance radiator
34.62%
Have the OE radiator re-cored (I still have it)
53.85%
Get another parts store cheapie. They have a lifetime warranty!
3.85%
Start the engine without a radiator (about 45 seconds) to get the car back into the shop.
7.69%
Voters: 26. You may not vote on this poll
Radiator EXPLODED!
Old Nov 15, 2022 | 04:26 PM
Radiator EXPLODED!
That's right. I started my 71 98 for the first time in several months this evening. While it was hesitant to start, I eventually got it idling. I added a bit of transmission fluid because the transmission was slow to go into gear and backed it out of the shop.
I dripped a little bit of ATF on the fender so I went into the house garage to get the detailer spray. In a matter of being away from the Olds for 30 seconds, the radiator blew the passenger's side tank off! Don't believe me, check out the pic!
When I came out to the backyard the the Olds was enveloped in steam. I thought it was on fire so I dropped the detailer, raced over and shut off the ignition. Coolant was still pouring out of the engine onto the ground as I shut off the car.
So, I sprayed off the car with the garden hose and got video washing it. You can bet your bottom dollar that I'm going to do a video on this! I just need to decide how I'm going to repair it. Make sure you vote on the poll and let me know what to do,
Old Nov 15, 2022 | 04:33 PM
Jesse - That's not a good way to end the day. Was it the original OEM radiator? Had it been apart for recoring or anything?
Old Nov 15, 2022 | 04:40 PM
Sugar Bear's Avatar
If the car is really nice and original get the OE one recored, if not just replace it.
Good luck!!!
Old Nov 15, 2022 | 04:46 PM
2blu442's Avatar
Scott Winn (oldspackrat) has several radiators for sale. He's got a post on facebook but you could send him a PM or email to ask what he has. Pretty sure one of his pictures had a 1975 4 row from an Olds 98 that may bolt in.
Old Nov 15, 2022 | 06:47 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Dang Jesse. Where the heck did you get a 50-pound radiator cap? Just kidding on that but wow. I have never heard of this. But then at 76, there is lots of stuff I haven't heard of. I vote for an aluminum replacement. The car is not a W30 show car, so you don't need to worry about it being original. The aluminum radiator will cool better.
Old Nov 15, 2022 | 06:49 PM
Good luck!!!
Unfortunately to get it recored, you need both original end tanks.
Old Nov 15, 2022 | 06:51 PM
That photo looks like it's a newer aluminum radiator with plastic end tanks. I've had a similar problem where the plastic tank split open while the car sat idling.
Old Nov 15, 2022 | 07:34 PM
Oldsguy's Avatar
Past Administrator
Damn those cheap plastic end radiators!
Old Nov 15, 2022 | 08:13 PM
Sugar Bear's Avatar
OP states he has the original in his poll.
Old Nov 15, 2022 | 09:49 PM
There is no right answer, do what you think is best. You can start it and get it back into the garage, it will make a mess.
Old Nov 16, 2022 | 04:50 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Wow, I have never seen that. I had a suspicious spot on the passenger plastic tank in my 94 Z71 open into a garden hose before my eyes but this is insane!
Old Nov 16, 2022 | 05:05 AM
You are correct gents. The radiator that blew apart was a parts store cheapie. I do have an OE style radiator that I replaced with the parts store cheapie. As I recall, the OE one wasn't leaking, it was one of those MAW projects.
Here's a short video:
I plan on filming the radiator removal and replacement. I will post the full-length video later this week. Of course, I'll have to revisit this once I get the OE replacement re-cored or a performance radiator.
Old Nov 16, 2022 | 09:50 AM
GCH's Avatar
GCH
Hmm , never heard of this before . Had Spectra Premium aluminium with plastic tanks in cars for
many years without any issue. Radiators with aluminium and plastic have been oem in Volvo for
many years also.
Old Nov 16, 2022 | 11:18 AM
harner's Avatar
1975 98 Regency Sedan
I had a plastic end-capped rad decide it hated life in my 06 Silverado, but it was the OE rad at 230k-ish miles. It did not explode, though - this is a first for me lol. That plastic must have been super thin and brittle. Wild!
I just put an ebay aluminum ran and efan setup in my 98. Surprisingly good quality for $200.
Old Nov 16, 2022 | 02:02 PM
Thanks for the comments gents. I installed the OE radiator and thankfully it holds coolant just fine. It took just over 4 gallons of coolant (the CSM says 17/20 quarts for the 455 in the non-Toronado/Toronado).
Unfortunately, I think a compression check is in my future. The engine smokes constantly while idling. It doesn't smell sweet though, it smells like nasty engine grime. I know the rings are worn. It would puff blue smoke during heavy acceleration previously.
I did some reading on our site and found that burning ATF from a faulty vacuum modulator creates white smoke. Maybe that is my problem? The transmission pan was pretty dry (it wouldn't move into and out of the garage without adding 1 pint of ATF both times). The transmission does leak but not as fast as the C6 in my Ford truck, and I only have to top that off (with less than a pint) after driving it around town for a week. I'll keep everyone posted.
Old Nov 16, 2022 | 02:29 PM
Sugar Bear's Avatar
Pull the vacuum line off the modulator, if it is dry you're good, if ATF is in it the modulator is bad. If the car has sat for a while I'd do a ring soak if the compression is weak. Valve seals are also a likely culprit for smoke at start up. Pull valve covers to check that the oil return drains are not clogged.
Good luck!!!!
Old Nov 16, 2022 | 03:07 PM
66_Jetstar's Avatar
Your rad probably exploded due to a bad head gasket or cracked head. I've seen this several times- excessive pressure in the cooling system from compression leaking in. Suddenly the rad goes pop! Diagnose the issue. Replacing the rad is treating a symptom, not the cure!
Old Nov 16, 2022 | 06:56 PM
I was wondering how an engine that was just started and was idling could heat the coolant to the point the pressure got high enough to blow the end tank off the radiator. Unless the tank was about to fall off already.
Old Nov 17, 2022 | 03:30 AM
Good point... Jesse, do you have a cooling system pressure tester? I had a engine once that had too much pressure. I put the pressure tester on the radiator cap with system full of coolant and cool. Started engine and watched the gauge go up as engine was idling, I didn't pump it up it went up on it's own. In my case it was a blown head gasket..
Old Nov 17, 2022 | 04:34 AM
Good point on the head gasket or cracked head. I had a Corteco head gasket go on an Olds 350, violent existing through the cap. Same thing on my Dakota with a 5.9 Magnum head gaskets then a cracked head. The radiators held together but talk about a ballooned upper rad hose. I have also had minor leakage at those crimped joints. Ford for years leaked a minor amount on their factory aluminum plastic rads at those joints.
Old Nov 17, 2022 | 05:18 AM
Yeah, that's what I'm afraid of. I will do a compression test this weekend. Sounds like it would be a good idea to get a coolant system pressure tester too, or at least rent one.
The thing is, the engine idles just fine. No lifter tick or rod knock. I will post a video on Friday.
Old Nov 17, 2022 | 05:21 AM
Why does everyone immediately go to the worst case? This has not been my experience with plastic radiator tanks. The plastic just ages, cracks, and boom. When this happened to me, a new radiator fixed the problem. There were zero issues with the engine.
Old Nov 17, 2022 | 05:29 AM
I hope that's the case Joe. I installed the OE radiator yesterday and it holds coolant just fine. I did start the car and pull it into the shop. The engine smokes like a locomotive, but it doesn't smell sweet like burning antifreeze. I also checked the manifold vacuum hose that goes to the transmission vacuum modulator. No ATF.
Old Nov 17, 2022 | 09:04 AM
66_Jetstar's Avatar
As I said- diagnose it!
the smoke plus the cold rad failure isn't a good sign.
Old Nov 17, 2022 | 01:48 PM
sysmg's Avatar
Take off the cap and run it, if coolant comes flying out, then it's the head gasket. You don't need a pressure tester for that.
Also in your video it looked like you ran it for a while with no coolant. That can't be good for the engine.
Old Nov 17, 2022 | 03:55 PM
66_Jetstar's Avatar
It doesn't need to come flying out to indicate a combustion leak. It may just dribble out which would be hard to discern as a problem. Best bet is a chemical test at this point.
Old Nov 18, 2022 | 06:33 AM
sysmg's Avatar
I just figured if we are contending that the combustion leak exploded the plastic tank then the pressure could be high enough to push the water out the outlet and it's an easy test. But your suggestion is more conclusive. Mine won't rule out a small combustion leak.
Old Nov 18, 2022 | 09:51 AM
The car wasn't running in the short video I posted above (what you hear is a combination of lousy video and an exhaust fan I setup in front of my shop). I show pulling my 71 into the garage in my full-length video (but it posts in 15 minutes). I filled the radiator with coolant and water and started the engine and I had to top it off with water. If it ran without coolant it was only for a few moments, I heard coolant pouring onto the ground as I shut the car off when the radiator first failed. I wasn't too concerned with getting video of that.
I'm going to do a compression test this weekend. I have a chemical tester to check for combustion gases in the radiator that I can use if needed.
Old Nov 19, 2022 | 10:21 AM
Dynoking's Avatar
You left out buy a quality replacement radiator from the pole.
Old Nov 19, 2022 | 11:03 AM
I included buying a performance radiator from the mail order/ online vendors (i.e. Jegs or Summit). Anything you can buy online I suppose you can get at the parts store but you will pay more for it. The radiator that exploded was the lifetime warranty unit from the parts store. Take that for what it's worth.
So, the head gasket is blown between cylinders 3 and 5. Here are the numbers:
1: 148 psi
3: 128 psI
5: 92 psi
7: 152 psi
2: 150 psi
4: 148 psi
6: 132 psi
8: 132 psi
I did the compression test dry, then I retested cylinders 3 & 5 by adding oil to the cylinders. No change.
The compression tester I owned broke. I went through all 8 cylinders and the schrader valve fitting wasn't working. I had to use the video to see how high it went. I tried to change the valve core but it got cross threaded and damaged the threads.
The compression tester from the auto parts store doesn't hold pressure at all. At least with my gauge it slowly leaked down.
Now the battery on the 71 is getting tired so, I'm done for the day. We'll see what I do next...
Old Nov 19, 2022 | 11:10 AM
  #31
Tough hearing about the outcome between 3 & 5 or 5 & 7. PITA dealing w/ inoperable equipment.
Old Nov 19, 2022 | 11:15 AM
  #32
Definitely a PITA. Thanks for the kind words Norm. I forgot to post the pic of the spark plugs. Here it is:
No steam cleaning on any of the spark plugs, but I attribute that to the fact that the engine has only run less than 5 minutes since the radiator exploded.
Old Nov 20, 2022 | 04:44 PM
  #33
Bummer Jesse. I blew a head gasket on a 73 350 Olds on the way down to Tennessee. We were going to come back home but decided to go ahead and finish the trip. Found out that 50-50 worked- no more than 50 MPH and stop every 50 miles to refill rad with water. Ended up taking 2 lane roads and went easy- made it down and back- Great trip!! Sorry to derail your thread but your story reminded me of that.
Old Nov 20, 2022 | 05:12 PM
  #34
We had this precise behavior at the H/O Nationals this summer. Head gasket failed, cracked the radiator. 83 H/O with a plastic tanked radiator.
Old Nov 20, 2022 | 08:44 PM
  #35
The cross threaded schraeder valve might be repaired with one of these 4 way valve core tools that should be available at your favorite auto parts store.
Old Nov 21, 2022 | 05:40 AM
  #36
No problem Greg. That would be quite a headache if a head gasket failed on the road.
I guess the plastic tank radiators aren't that strong. The failure would have been even more violent if the OE radiator failed, it's all brass and copper.
Good idea, I'll have to get one of those. Thanks for reminding me.
BTW, here's a pic of the heads in the back of my truck. I'll go ahead and drop them at a machinist today. I decided to tear down the engine yesterday. No steam cleaning in any of the cylinders.
Old Nov 21, 2022 | 08:42 AM
  #37
I actually think a blown head gasket on an OEM copper radiator would not be violent, it would just pressure fill the overflow. I think the plastic tanks cannot handle the pressure transient of the combustion gas before the radiator cap unloads it. Perhaps the copper tanks can hold the pressure while the cap vents.
Old Nov 21, 2022 | 02:00 PM
  #38
66_Jetstar's Avatar
The first car I experienced this on was the cutlass I drove in college with a 307. It blew the upper outlet off the radiator. That was a copper rad. I had no idea why so I simply replaced the rad with a used plastic tank unit from my brothers trans am. That made it about a week and the tank split on that. I started to figure out what the issue was after that..
Old Dec 2, 2022 | 11:32 AM
  #39
Here's a video of my compression test:
I actually heard from the machinist today. He magnafluxed the heads and they're good cores. He said it would be over $1000 for the works. Including new valve seats, springs, guides, etc. He mentioned there are rotators on the intake valves and none on the exhaust valves. He sounded surprised. I knew Oldsmobile used valve rotators on top of the springs in the day.
I mentioned to him that $1000+ was too much. Especially considering that I'm not going to do anything to the short block and it has 90k+ miles. He revised his quote and said he could do it for $420 with new guides and cutting the valve face and seat without new seat inserts. I agreed and he says he should have it done before the holiday.
Old Dec 2, 2022 | 11:49 AM
  #40
That is correct for a 1971 455 other than 442, per the CSM.
