Question about a set of Ka heads.
If there's anyone in forum that's familiar with Ka heads would you mind taking a look at these pics, and tell me if they look stock to you. I need a set of heads to rebuild and these are available to purchase. Thanks for any information you might have.
Mike
Mike
They look like good cores to me. I would rebuild and use. Not sure if you have these or looking to buy them? If buying whats the price? Ka are good heads. I use to buy and sell parts, never had a hard time selling any off them.
Mike,
They look like they have had machine work done to them. If you look around the od of the valves there is a fresh machined looking area. They have either had seats put in them or the seats have been machined. It does not look like they have been surfaced ? The heads are also "clean" so they have probably been hot tanked or shot blasted in the past which also tells me they have prnobably had work done to them.
There is also a suspicious looking spot on one of them. Looks like bad pitting and maybe like the head gasket had bee leaking between the two cylinders. I attached a picture of the area in question. Might just be the light in his picture.
Is the seller near you ? Will he guarantee that they are not cracked ? Other than cracks most anything else can easily be repaired but at what cost ? I am not familiar enough with Olds head prices to advise you on that part.
Bill, Thank you very much for your thoughts. Unfortunately the seller is two hours away. I haven't asked him if he would guarantee them to be crack free, but I believe he will. I'll ask before I go any further. I was a little puzzled when I looked at the pictures. It was my understanding that the Olds heads with hardened seats were induction hardened. To me the heads look like they have inserts. I see the area where your concerned about, I blew the picture up but couldn't really see anything clear enough to tell anything.
Mike
Mike
Mike, they may be a fine set of heads to rebuild. But if your driving 2 hours and paying $500 I'm certain one of us here could sell and ship you a set for less. If you want to explore that I have several sets of Ka's plus many other castings. I also have some rebuilt heads on the shelf. Send me a PM if you want to discuss it more and see some photos. John
Mike
Mike
Personally I think I would pass. There must be a set of heads available that have not been messed with. The only other option is find a machine shop close to the seller and see if he will take them there for them to look at ? Offer to pay the machine shops bill for check out.
I'm not sure how that would work out for me. With tax that's almost $2500. Then they would need to go to a machine shop to be disassembled and inspected and repairs made if needed.
Bill, the only reason I was looking at the Ka heads was because they were new enough to have hardened exhaust seats. The car is going to my brother and I didn't want him to have any trouble with the car down the road. I really couldn't tell which of the other heads might have hardened seats. It's only a reliability issue as far as the heads go because the engine is a low to mid rpm torque engine.
Mike,
I dont think that is really an issue with Oldsmobile heads like it is with some makes. And it is rarely an issue on any engine that is a hobby driven type vehicle. What engine are they going on ? If you are really concerned with it you could have hardened exhaust seats put in any head.
you don’t even need the so called induction hardened seats which all have retainers that rotate the valve.
you can use any head, if they came with rotators, chuck them in the garbage if you feel like it. They are horrible for keeping the the spring from walking all over the place and chewing up the guide.
I’ve seen more heads screwed up by shops installing seats that didn’t need them in the first place
Bill I'm sorry I couldn't get back to you sooner. The heads were reworked years ago, and when I picked them up you could see the different heights of the valves in the head. I decided to just add adjustable rocker arms rather than deal with the problem at the time. With what you and others here have told me about not needed hardened exhaust seats I've decided to have a set of C heads that I have reworked by a much better machine shop that I have access to now. Thank you again for taking the time to help me with this.
Mike
Mike
