Quadrajet vacuum break adjustment
Old May 14, 2026 | 11:05 AM
August442's Avatar
I have a 1970 442 with the stock Quadrajet & turbo 400 trans. I have the bogging problem when I really get on the gas. If I slowly push the pedal down the car has tremendous power.
I checked the vacuum break dashpot & found that it leaks. I got a new one. I adjusted the dashpot as shown in the repair manual. before changing the dashpot, I had been adjusting the
air valve spring to no avail. I set the air valve spring to 3/4 turns after the flaps just closes (like what it says in the manual). Again, no real change. My question is do I just keep making
the air valve spring tighter till it slows the flap opening? or is something else wrong. I'm sure this has been addressed before but my search didn't answer my question.
Old May 14, 2026 | 01:11 PM
have you checked the accelerator pump for correct operation? If it's not squirting (enough) fuel, it can cause the symptoms you described.
Old May 15, 2026 | 05:10 AM
August442's Avatar
I didn't check the accelerator pump. The carburetor was rebuilt about two years ago. That's a good idea. I will check to see if it's squirting.
Thanks for your help.
Brad6298
Jan 9, 2025 09:19 AM
ourkid2000
Tech Editor's Desk
May 27, 2024 04:24 AM
jpilk99
Jul 20, 2023 02:40 PM
kuseetha
Jun 24, 2023 05:48 AM
Scottwhite98
Jul 19, 2016 07:02 PM
