quadra-jet differences
Old Aug 30, 2016 | 02:17 PM
deadeyejedi's Avatar
just curiuos if there are any real differences as far as performance goes between a rochester quadra jet from a big block olds in 1970 as opposed to a 1976 big block olds? .assuming both are stock .
Old Aug 30, 2016 | 02:52 PM
Yeah. The 1976 carb will have leaner jetting and more "features" to operate emissions equipment like EGR. Certainly you can change the jets and rods in the later carb to match the early one, however.
Old Aug 30, 2016 | 04:36 PM
Sounds good thanks joe
Old Sep 3, 2016 | 06:58 PM
marxjunk's Avatar
and the 76 will be an 800cfm more than likely
Old Sep 3, 2016 | 07:01 PM
The later carb will have the better sealing main well plugs, adjuatable part throttle, and more than likely the better needle and seat setup. Once you make the necessary calibration changes it will work just as weel or better than the factory carb.
Old Sep 5, 2016 | 08:43 AM
i finally dug out the old quadra jet from my 1970 455 .but i ran the numbers and it came out as a 1973 350 carb .can someone double check for me?carb number is 7043250 ra .im sure it could have been replaced years ago
Old Sep 5, 2016 | 08:54 AM
tru-blue 442's Avatar
Old School Olds
You are correct, 73 Olds 350.
Old Sep 5, 2016 | 10:19 AM
FYI, the third digit is the decade (2 = 1960s, 4 = 1970s) and the fourth digit is the year (43 = 1973).
Old Sep 5, 2016 | 06:19 PM
Great thanks for the help guys
Rocketbrian
Dec 20, 2015 05:43 PM
Olds442redberet
Jan 26, 2014 06:46 PM
ent72olds
Mar 20, 2013 01:22 PM
DAN76
Jul 24, 2009 09:01 AM
pete w
Sep 5, 2008 01:23 PM
