Pulley help
Old Dec 6, 2024 | 07:33 AM
Tirediron's Avatar
Pulley help
Hi all,
I've recently got a 455 for a remotoring project. It came without any pulleys or alt or PS pump. I'm trying to sort out which pulleys I need and, while there is lots of info out there, some of it is confusing to me and some of the pdf scans are too fuzzy to read.
I have a water pump with a 6" snout, so I'm assuming that determines everything else. I don't need AC, so alt on the R and PS on the left and 2 grooves on the crank pulley...correct?
Here's what ive gleaned from a post that showed a diagram for a 2 belt system, tho it appears that this might be for a shorter snout water pump so won't work for me. I'd sure appreciate someone getting the right numbers for me. Thanks, martinWater pump 405462, 405461 km
Crank 405459 kj
Power steering 399483
Gen 1102448, 1102441 ec, ld
Power steering belt 399594 mm
Gen belt 399598, 405594 lc, mc
Old Dec 6, 2024 | 11:09 AM
VI Cutty's Avatar
Someone wiser than I can tell you whether or not there are 2 groove pulleys for the 6" water pump, but considering the engine looks to have had a rattlecan rebuild maybe it's time to replace the waterpump anyways? Then you can get a waterpump to match pulleys and not be stuck where you're at now?
I went down the "what pump, what pulleys" rabbit hole in a thread a while ago. The answers there may be helpful if you change the water pump. https://classicoldsmobile.com/forums...dation-176258/
smparr
Jul 5, 2023 06:42 PM
Monoplane
Mar 16, 2023 08:44 AM
Kreisk
Jun 5, 2022 07:20 PM
tictoryde
Oct 15, 2021 07:23 PM
yachtsmanbill
Oct 29, 2019 04:12 PM
