Non-Oldsmobile Classified Please read forum guidelines before posting.
Mostly Buick stuff
Old Oct 29, 2019 | 04:12 PM
yachtsmanbill's Avatar
Mostly Buick stuff
Just doing a fall cleaning, and have a bunch of stuff that needs to go. Anything is is priced at reasonable numbers, or best offer plus ACTUAL USPS shipping from 54241. PM's with emails for more pics are welcomed! Bill in TR at yachtsman36@charter.net
Most of this stuff is from my '64 V6/3 on the tree (34,000 original miles) and some stuff is from my 72 455 XGS. If youre not sure, shoot me parts numbers and sizes for due diligence please. Trades considered! A lot of Olds stuff interchanges with Buick!
'64 V6 OEM perfect radiator 25.00
'64 perfect shroud with soft side seals (two clip holes are torn) with core support clips 25.00
Original spiral shocks for the rear. Dirty, not too rusty, for RESTORATION for that concurs car! 10.00/pair
v6 or 455 aluminum alternator bracket/NON A.C. nice 35.00
47A (?) alternator as removed for that numbers correct core deal 20.00
2 NON OEM older voltage regulators. 10.00 both
Alternator adjusting bracket for 1964 cleaned and painted 15.00
Pair of 64-67(?) upper radiator mounts 20.00
17 inch 4 blade fan 20.00
2 fan mounting hubs, different lengths 10.00 each
V6 (300 also??) complete crank and water pump pulley set 20.00 (cast iron?)
430/455 NON AC water pump pulley 20.00
v6 motor mounts and frame pads as removed 10.00 set
1964 column shift (manual) linkage 10.00
1964 BLUE column shift lever (manual) nice chrome 10.00
ANTENNA mounting teardrop (chrome bezel) and black plastic nut (OEM!!) 35.00
1964 glove box door minus latch 10.00
FOUR 14" poverty wheels with F-78 tires 10.00 ALL 30.00 with tires removed!
THREE Special DeLuxe full wheel covers. Nice 25.00 each.
Very decent 1964 &65(?) rear valance tri shield badge. Very minor pitting 75.00
NICE ruby red tail light lenses 35.00 each
NICE reverse lights with GOOD chrome bezels 35.00 each
1972 A6 AC compressor , locked up for a core 20.00
1972 AC desiccant drier, (new) used 10 minutes for an R12 experiment, has the R12 oil in it. 10.00
1972 OEM expansion valve 5.00
1972 POA valve as a core or mock up only. 10.00
1964 NON AC heater core. Needs recoring (single leak!) all brass unit 25.00
1964 Glove box latch. Complete, no key, disassembled 30.00
Bought new, now used 300 miles, Edelbrock 800 CFM carb with electric choke, AN6 fittings, tuning book and spare jet pieces 300.00
Aluminum 1" spacer for above carb to quadrajet manifold 10.00
Lightly used fuel pressure gage 15.00
V6 OEM fuel pump as removed. Looks good. NON TESTED 10.00
V6 (300?) timing chain tensioner parts. UNOBTANIUM 25.00
1964 and 1972 OEM body and engine bolts. Most are cleaned and oiled. 5.00/pound ! Send sizes required !!
1964 three speed manual trans front driveshaft yoke with U joint minus 2 caps, as removed. No seal area wear 20.00
1964 8.2 2:73 open rear end with brakes and drums. WILL NOT SHIP! 100.00
1964 DIY boxed lower control arms. With OEM bushings. No sway bar holes 30.00
1964 OEM fuel tank. Non leaker, rusty inside, needs a good cleaning! Good filler neck 20.00
1965 GS core support. I drilled and removed bottom crossmember for my project. Remains are still welded. Good for parts, will disassemble. INQUIRE
BAD 455 crankshaft. Good for core for a stroker grind. 10.00
455 rocker shafts with 16 rockers. Useable or for mock up. Minimal wear. 20.00
455 painted valve covers. Just about perfect 45.00
455 valve covers. Small dent by brake booster 25.00
V6 (ALL V model Buicks!) cast iron thermostat housing 25.00
455 Camshaft. As removed from a running engine. Good enough that it burned the crankshaft up! Can provide numbers. Good for mock-up 15.00
TWO sets of front springs. One pair 1964 V6 and one pair 1967 GS 400(?) As removed, lengths per pair are good. 20.00 pair
455 POSITIVE battery cable conduit 25.00
1964 V6 clutch disc,pressure plate and throw out bearing. Disc is "fair", plate is rusty/rebuildable, T-O bearing is good. AS REMOVED! 20.00
Oct 16, 2019 06:59 AM
johnbumb@charter.net
Oct 2, 2018 05:43 PM
panther80
Jun 5, 2013 05:19 AM
BOOWAH
Oct 18, 2010 06:11 AM
69convertible
Ninety-Eight
Dec 8, 2008 05:39 AM
