Pull water pump and timing cover???
Old Apr 24, 2018 | 04:54 PM
rick442's Avatar
I was removing my oil pressure sending unit and the dang thing broke. I was able to back out the brass threads stuck down in. I was careful but I got a couple of micro particles down the hole. I took a q-tip and swabbed the hole and the landing down in there. I snagged a few particles. Very tiny and can only see if reflecting light.
Now for the dumb question, should I pull off the timing cover? There is only few thousand miles on the engine.
thanks,
Old Apr 24, 2018 | 07:07 PM
Make a short hose to thread into the oil sender hole, put the other end of the hose into a bucket. Add a couple extra quarts of oil, have a helper start the engine, make sure your helper shuts down the engine before you drain the oil pan.
Old Apr 24, 2018 | 07:09 PM
Btw, pulling the timing cover will gain nothing. There is no acces to the oil passage without engine removal and complete tear down
Old Apr 24, 2018 | 07:25 PM
^^^THIS. Personally, I'd adapt a straw to the end of a shop vac hose and stick it into the oil pressure fitting hole.
Old Apr 25, 2018 | 06:59 AM
rick442's Avatar
Thanks Guys! you saved me some stress and more work....
I did vacuum out the hole and swabbed it again and could not see any debris.
I'll do Matt's idea as well. I'm redoing the whole engine compartment, so it may a a week or two.
I'll keep you posted.
Old Apr 25, 2018 | 07:03 AM
A few micro particles of brass will not hurt anything. I wouldn't even worry about it.
.Rocket.Man.
Jun 4, 2015 02:06 PM
1971viking
Jul 11, 2012 11:32 AM
69OldZman
Jul 1, 2010 07:21 AM
442scotty
May 13, 2009 05:42 PM
