Pro Comp head/valves?
Old Apr 3, 2018 | 04:53 PM
nwcajun's Avatar
So I have a set of Procomp 455 heads with one side needing valves (the way I purchased them), I have read where these valves aren't favorable. What valves and springs should I run in them? Figure it would be smarter to replace them all than buying more procomp valves.
Are there valves trash or just the springs/retainers? I will admit $140 for all 8 intake and 8 exhaust is a heck of a deal for olds valves.
Old Apr 3, 2018 | 09:07 PM
VinMichael's Avatar
I have Manley intakes and Trick Flow exhausts. Springs, retainers, and locks are supposed to match your cam.
Old Apr 3, 2018 | 09:17 PM
nwcajun's Avatar
I have Elgin cam and lifters, I was looking at getting there springs as well. I'm going to run comp cam die cast full roller rockers and guides.
Old Apr 3, 2018 | 09:45 PM
VinMichael's Avatar
I’m running PRW 1.65 stainless full rollers. Edelbrock guideplates 3/8” with restricted hardened pushrods. Erson springs installed at 1.800”. Had to stack .110” worth of shims. Shim on top is .050” and is hardened.
Used Comp viton seals.
slam1918
Jul 25, 2013 04:31 AM
Delmont 88 PA
Jul 19, 2012 04:43 PM
Olds Man
Mar 28, 2012 06:14 PM
firefrost gold
Dec 19, 2011 01:00 PM
