Pro Comp Head Compatability
Old Jul 22, 2013 | 06:42 PM
slam1918's Avatar
I have ordered a pair of pro comp heads from Bernard. With roller rockers I will need new valve covers and bracket modifications for the alternator & A/C . I would prefer to maintain a stock looking valve cover.....any suggestions.....
Old Jul 22, 2013 | 06:55 PM
ihengineer76's Avatar
Order a pair of chrome tall valve covers with no script, sand blast them, then paint them.
Old Jul 22, 2013 | 10:42 PM
I bought some cheap aluminum valve cover spacers off ebay. I think I paid $75 for them. I used stock Oldsmobile script valve covers. My Crane roller rockers fit with room to spare.
Old Jul 22, 2013 | 11:05 PM
RAMBOW's Avatar
Ben
my factory covers came very close to fitting with harlandsharp rollers & polylocks. I doubled up the gaskets and they fit fine- so do the M/T aluminum covers.
Old Jul 23, 2013 | 02:01 AM
slam1918's Avatar
eBay is showing $ 29. For "tall" valve covers. Anyone have first hand knowledge of the quality & the seller? If you double the gasket do you need longer bolts?
Old Jul 23, 2013 | 04:35 AM
coppercutlass's Avatar
Chevy budget Olds powered
I run the cheap ebay tall covers on my engine but it's iron headed. They fit good. I has to notch the dr. front top corner to clear the bracket for the alternator. I just banged it to fit with a hammer. That area gets hidden anyway.
Old Jul 23, 2013 | 07:43 AM
455man's Avatar
Regular bolts work with double gaskets. I also slightly dented the baffle on the inside to clear the poly locks.
Old Jul 23, 2013 | 08:22 AM
slam1918's Avatar
Ohhhh Copper your killin me. Did you use a claw, plastic, sledge or ball peen ?
I think the deck stands a little taller with the pro comp head.....can someone throw me a bone here. What about the A/C bracket , the one I a bit huskier that the alt. any opinion on K&N vs R2C air filter??
Old Jul 23, 2013 | 08:33 AM
Slam I'm a body man so I used a body hammer. But claw hammer will work lol. They are only 30 bucks so if you beat them I don't think you lose much the chrome tall ones are onlt 3/8 taller than stock.
Old Jul 23, 2013 | 08:51 AM
slam1918's Avatar
There are a couple of eBay merchants, any one better than the other??
Old Jul 23, 2013 | 09:43 AM
The vendor with the best reviews
Old Jul 24, 2013 | 07:38 PM
442rocketdave's Avatar
Just get the ones from Ebay for 30 bucks and buy a set of Edelbrock valve cover gaskets they are 1/4 inch thick and it will clear your roller rockers and as for the Altenator bracket a little die grinder will help it clear and the A/C just use spacers! It takes some finagling but you will get it!
Old Jul 25, 2013 | 04:31 AM
slam1918's Avatar
thank you rocketD....any experience with the 2RC air filter??
nearma12
Mar 7, 2022 08:49 PM
CanadianCutlass
Oct 15, 2014 09:42 PM
Delmont 88 PA
Jul 19, 2012 04:43 PM
Olds Man
Mar 28, 2012 06:14 PM
firefrost gold
Dec 19, 2011 01:00 PM
