Block repair??
Old Jul 21, 2013 | 05:35 PM
jeff84hurst's Avatar
Block repair??
I was taking of exhaust manifolds and cleaning all the grease on the BBO 425 and noticed what looked like a repair on the side of the block. I am not sure take a look and tell me what you see to the left of the dipstick.
Old Jul 21, 2013 | 06:11 PM
65B01Delta's Avatar
Looks like the block was cracked at one time and repaired by welding it..
Old Jul 21, 2013 | 06:39 PM
thats pretty much what i thought...I think I know of a bare 1965 425 block for 150. I dont want to chance it.
Old Jul 21, 2013 | 06:41 PM
+1. If it was just the water jacket, it may be okay.
Any bad symptoms?
Old Jul 21, 2013 | 06:53 PM
65B01Delta's Avatar
If you get another block you'll have to do a rebuild. I would drive as is, no telling how long ago it was done.. Looks like a good weld job.... Drive it.
Old Jul 21, 2013 | 06:56 PM
Octania's Avatar
If it's properly repaired, it's serviceable
Old Jul 21, 2013 | 07:11 PM
Any bad symptoms?
I got this motor from someone else to put into a 1984 Hurst Olds. I was taking off manifolds and trying to clean it up and seen it. I haven't had it in the car yet.
Old Jul 21, 2013 | 07:42 PM
steverw's Avatar
take it to a machine shop have them check it, it may be ok
Old Jul 22, 2013 | 07:07 AM
If it wasn't leaking before, it will be fine. This is just the cooling jacket.
Old Jul 22, 2013 | 08:34 PM
I might have to take drivers side cylinder head off anyway. I snap the heads off of 2 of the exhaust manifold bolts , unless I can vice grip them out. I talked to previous owner and it was a water jacket repair.
Old Jul 24, 2013 | 02:19 PM
I got one bolt out with some vice grips, penetrant, and heat. I might need to call someone for the other one. I might go get some PB blaster and soak it for a couple weeks and see if it will budge. I only have a MAPP gas torch to heat it up. The bolt is sticking out about 3/4" and all the threads are gone from trying to vice grip it out.
Old Jul 24, 2013 | 07:44 PM
You need oxy/acetylene.
More heat should do the job without a problem - just heat judiciously, and don't set the car on fire.
Old Jul 25, 2013 | 09:55 AM
507OLDS's Avatar
Looks like a water jacket that froze & cracked.As long as it was welded correctly,it should be fine.With cast iron,it should be heated up and glowing red,then welded.
If a block is cracked in that area,I just fill it with hard-block,block filler.which is basicly cement.
If you do end up switching blocks,and you have a 425,make sure you get a good match to swap.There are a few different 425 blocks,with different lifter bore sizes and lifter bore angles. You can also put the 425 internals into a 455 block.
Old Jul 25, 2013 | 11:28 AM
Thanks I was looking for a 455 block as well. I know of none that's totally complete its a got J heads and has work done to it. I finally got all the rusted , broke exhaust bolts out. If anything I'll just go ahead with my build using the motor I got. Next thing will be to clean the motor up it has a lot of grime on it.
bocoogto
Aug 26, 2023 06:09 PM
antweave
Apr 22, 2011 11:32 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
