Priming a 400 before starting
Old Mar 18, 2014 | 11:10 AM
442craig's Avatar
Hi Guys,
I'm at the stage (finally) of starting my new 400. Any suggestions or tips on priming the oil pump?
Thanks,
Craig
Old Mar 18, 2014 | 11:31 AM
442craig's Avatar
I just realized this topic has been covered a few times. Sorry about that. I guess to further my question, do you have any tips for starting procedures? It is a 68 400 roller cam motor. I've seen that a 5/16 hex socket is the tool used to spin the oil pump. Can I just use a socket with an extension hooked to a drill? Or is there a special tool? Do I spin it counter clockwise? I assume the oil pump is free of the distributor gear. Meaning it wont affect the position of the distributor when reinstalling. Right? Sorry if this seems basic. I didn't build the engine so I'm unfamiliar with the guts!!!!
Looking forward to SUCK-SQUEEZE-BANG-BLOW
Thanks!!
Craig
Old Mar 18, 2014 | 12:06 PM
455man's Avatar
Yep just hook a socket with extension to a drill. It has been recommended to duct tape them together so nothing falls in your engine. Counterclockwise. Oil pump is separate from cam gear. Its turned by the rod that connects to the bottom of the distributor.
Old Mar 18, 2014 | 12:07 PM
Nop's Avatar
Nop
2-stroke 1-cylinder guy
S:"prime drill counterclockwise":
https://classicoldsmobile.com/forums...mp-primer.html
Old Mar 18, 2014 | 02:28 PM
I prime engines until I see oil running over all rockers. It takes a while sometimes.
Old Mar 18, 2014 | 08:44 PM
442craig's Avatar
Thanks guys, just want to protect the investment!!!!!!
bccsrc
Nov 29, 2011 11:08 PM
D Appeldorn
Nov 6, 2010 04:03 AM
JRios
Sep 29, 2010 08:39 PM
dallasite21
Aug 31, 2010 07:54 AM
Wasted
Nov 22, 2008 05:59 PM
