power steering pump bracket and pressure hose - plz have a look
Old Sep 8, 2014 | 09:33 AM
Thufir's Avatar
Hi!
The PS pump on my Turnpike Cruiser E400 is leaking oil. Therefore I looked closer and found out that the bottom bracket screw wasn't tight on the block. BUT it took a lot of force to tighten the screw only a small bit and I got anxious to ruin the thread.
1. Question: Is there supposed to be a spacer between bracket and block that is just missing? Or is the bracket bent? Or should I just attack the screw with more force?
The leak seems to come from the pressure hose, where the hose is fixed by the metal clip.
2. Question: is it possible to repair a pressure hose or should I get a new one?
Many thanks in advance! Cheers Thufir
Old Sep 8, 2014 | 10:09 AM
pogo69's Avatar
morgan
i'm pretty sure it has a spacer for your year, my 69 has a spacer...good thing you realized your were bottoming out before you made more work for yourself
Old Sep 8, 2014 | 11:48 PM
Thufir's Avatar
Many thanks for the fast response!
After further research and a closer look in the assembly manual I found out that there is supposed to be a stud with two nuts fixing the battery cable between block and bracket - it seems over the years some mechanic decided to reroute the cable ^^
Any recommendations to the leaking pressure hose? Is it possible to tighten the metal clip at the end?
Cheers - Thufir
ROCKET VAPOR
Mar 25, 2014 03:26 PM
nicks1966
Jan 12, 2014 01:46 PM
jjbjr64
Dec 4, 2011 10:20 AM
xerxes600rr
Aug 30, 2011 06:43 AM
gerlof_1
Apr 23, 2008 11:09 AM
