Power steering Bracket 71 442
Is the Power Steering the same for a 350 as it is for a 455? My bracket is to long the front of the bracket is in line with the first groove on the water pump and flywheel pulleys. the car has A/C the brackethas a 1 3/4" offset. I got a diffrent bracket today it has the same bolt hole pattern but is made a little different. but it has the same offset. Iam not sure the car has the right bracket nothing else has been right.
They should be the same for 455 and 350. There are different variations, but all bolt up in the same location. Alignment issues usually stem from mismatched pulleys, missing spacers, or an incorrect water pump length.
my flywheel pulley the water pump and the altenater line up fine. the water pump has the right numbers stamped on it. it looks like the power steering will be lined up with the front 2 grooves instead of the back 2. The fly weel and the water pump are 3 groove
nicks1966
January 12th, 2014 01:46 PM
xerxes600rr
August 30th, 2011 06:43 AM
Steve Wike
August 22nd, 2010 06:45 PM
