Power steering Bracket 71 442
Old Jul 24, 2012 | 07:59 PM
Terryc's Avatar
Is the Power Steering the same for a 350 as it is for a 455? My bracket is to long the front of the bracket is in line with the first groove on the water pump and flywheel pulleys. the car has A/C the brackethas a 1 3/4" offset. I got a diffrent bracket today it has the same bolt hole pattern but is made a little different. but it has the same offset. Iam not sure the car has the right bracket nothing else has been right.
Old Jul 24, 2012 | 08:05 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
They should be the same for 455 and 350. There are different variations, but all bolt up in the same location. Alignment issues usually stem from mismatched pulleys, missing spacers, or an incorrect water pump length.
Old Jul 24, 2012 | 08:09 PM
stampings KF water, KC crank, and KH power steering should all line up perfectly in a 71 with a 5.6" water pump snout.
Old Jul 24, 2012 | 08:14 PM
Terryc's Avatar
my flywheel pulley the water pump and the altenater line up fine. the water pump has the right numbers stamped on it. it looks like the power steering will be lined up with the front 2 grooves instead of the back 2. The fly weel and the water pump are 3 groove
Old Jul 24, 2012 | 08:19 PM
Then it is possible you have the incorrect power steering pulley.
Old Jul 24, 2012 | 08:33 PM
Terryc's Avatar
My P/S is a KH the Water Pump is a KE my book says it should be a KK the fly wheel is a aftermarket but is in line with the water pump. any one know the differance between a KE an KK?
Old Jul 25, 2012 | 03:43 AM
KH steering goes with KF crank pulley, a 5.6" water pump and KC water pump pulley. These are the correct pulleys for a 71'
KK and KE won't work with that steering pump.
Old Jul 25, 2012 | 06:59 PM
Terryc's Avatar
I found out today I have the wrong crank and water pump pulleys. I have the correct ones ordered. Thanks, Terry
nicks1966
Jan 12, 2014 01:46 PM
Terryc
Jul 24, 2012 07:47 PM
xerxes600rr
Aug 30, 2011 06:43 AM
Steve Wike
Aug 22, 2010 06:45 PM
mcutlass1969
Jan 8, 2007 06:36 AM
