Performer 455 center divider mods
Old Nov 22, 2023 | 06:29 AM
rjh45's Avatar
I'm looking for instructions on the center divider mods to the Edelbrock performer 455 intake. I used the search engine with no luck. Thanks.
Old Nov 22, 2023 | 09:01 AM
Do you mean the exhaust crossover, or do you mean the divider under the carburetor?
Old Nov 22, 2023 | 01:33 PM
rjh45's Avatar
Divider under the carburetor.
Old Nov 22, 2023 | 04:29 PM
I have seen the divider cut down on lots of manifolds at swap meets. I’m not really sure why or what the advantage supposedly is?
It seems to me if it was beneficial, Edelbrock would have cast it that way.
Old Nov 22, 2023 | 06:31 PM
VI Cutty's Avatar
Bernard Mondello posted some images and maybe a video of the modification on his facebook page a year or two ago. If you use fb, try searching his page.
Old Nov 22, 2023 | 07:20 PM
pav8427's Avatar
A simple half of half dollar sized notch on centerline of the back barrels is usually all that is needed.
Same effect can be done with the Olds 3 hole carb mounting gasket when using a quadrajet.
Old Nov 23, 2023 | 02:01 AM
455rkt's Avatar
I have seen just the notch in the dividers underneath the secondaries, as well as the whole divider trimmed down. Some say it promotes plenum sharing as well as adds a little plenum volume. There has been much debate on if there is anything lost with the Torker manifold and it's single plane,open plenum design over a performer or RPM, so I doubt there are any ill effects to trimming down the divider. You are essentially getting a similar plenum sharing effect as using an open spacer under the carb, without the additional height and volume.
From his facebook page mentioned above, Bernard Mondello puts his manifolds in a mill and mills down the divider, then smooths it out with a die grinder. From his post:
"On the Edelbrock performer RPM we go 1.000" deep!
On the Edelbrock performer we go .800" deep!
Thank you in advance,
Bernard Mondello Racing Enterprises"
Old Nov 23, 2023 | 03:08 AM
I've only ever heard of milling the intake manifold divider to help an aftermarket EFI system idle properly. I don't think it's necessary when running a carburetor.
Old Nov 23, 2023 | 05:56 AM
The need to mill a divider or not depends on the engine, the cam, the induction system, and the intended use. If milling the divider was best for every application, Edelbrock would have done it at the factory.
Old Nov 26, 2023 | 07:39 AM
OLDScience's Avatar
Actually Edelbrock does do it from the factory. Look at the performer RPM v. performer RPM airgap for SBC.
Old Nov 26, 2023 | 05:57 PM
VI Cutty's Avatar
I don't know if anyone has done any testing to determine whether the modification improves performance or not. I bought the majority of my engine parts from Bernard, and he recommended the modification, even called my machine shop to let them know his specs for it. The engine's a 455, .030 over, mild cam, Edelbrock heads cleaned up by Bernard and a Quickfuel 850 carb.
Old Nov 28, 2023 | 01:55 PM
cutlassefi's Avatar
Normally it adds hp in the upper rpm range with no loss below it.
A more important aspect is distribution. If you saw the range of EGT’s on a typical dual
plane, you’d be surprised.
rocketboy
Nov 27, 2021 06:19 AM
takeman
Mar 24, 2018 06:39 PM
brownbomber77
Oct 26, 2015 07:16 PM
68Delta88
Nov 1, 2012 06:15 PM
The_Jeremiah
Mar 7, 2009 09:01 AM
