Olds 496 w/ serpentine convertion 582hp/647 trq
Old Dec 16, 2020 | 04:23 AM
O.P.LARRY's Avatar
Installed the serpentine convertion w/ all new accessories.
Engine makes 582hp/647trq
455 stroked to 496ci
BTR offset pushrod Edelbrocks 5 axis cnc ported finished by me
CP pistons
Scat rods modded to fit the Olds crank journals
torker intake
Roller cam(Cant recall spec, I'd have to dig them out) Not very big though because I didn't want to change vavle springs every year
Est 10.4-1 compression
I make and sell the adapter plates to mount the Chevy brackets to BBO & SBO
I also make and sell the shinny thermostat housing as well.
Old Dec 16, 2020 | 08:07 AM
VORTECPRO's Avatar
Very nice!
Old Dec 16, 2020 | 08:50 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Larry's brackets are nice an this build is awesome. Flowkooler has a pump to work with these.https://flowkoolerwaterpumps.com/pro...7bab2ade&_ss=r
I really like them on my 88. There is adapter brackets to run the Sanden compressor in place of crappy R4 compressor, my thoughts down the line when I add aftermarket A/C to the 70S.
Old Dec 17, 2020 | 03:37 AM
O.P.LARRY's Avatar
Thanks for the postive feedback. Appreciate it.
Old Feb 4, 2022 | 12:16 PM
oldsmike1972's Avatar
Can you provide a link for the brackets using the Sanden compressor?
Thanks in advance,
Mike
Old Feb 4, 2022 | 03:18 PM
https://www.dirtydingo.com/shop/mobi...-vVa3cU.mailto
The install instructions show the breakdown and on a motor.
Old Feb 4, 2022 | 05:49 PM
Thanks! Appreciate it!
Old Dec 22, 2024 | 06:38 PM
JRonGuitar's Avatar
Interested in your bracket kit Larry. How can I contact you? Thanks
Old Dec 24, 2024 | 09:37 AM
Unless you have access to a Olds V6 diesel RWD reverse rotation water pump, it will be difficult to make it work. I got the second to last reverse rotation RWD diesel water pump Flowkooler could get. I have a back up, just in case. They are no longer available anymore, is my understanding.
69Chrgr
Apr 24, 2021 07:50 AM
Gary M
Dec 15, 2019 06:18 PM
Bob Kelso
Jan 19, 2019 10:32 AM
76olds
Jan 19, 2014 04:19 PM
coppercutlass
Jul 8, 2013 07:56 PM
