Olds 455 Flexplate Help!!!
Old Jul 19, 2015 | 12:44 PM
Jolly Green's Avatar
Exclamation Olds 455 Flexplate Help!!!
Hey guys, we are trying to bolt up our Olds 455 with our transmission but is there a way to "clock" the flexplate to the crank shaft? Its externally balanced obviously, and we see the "chunk" in the crankshaft. But does it matter? Thanks!
Old Jul 19, 2015 | 01:03 PM
2blu442's Avatar
Jolly, the holes are not evenly spaced. If you set the flexplate against the end of the crank you can rotate it around and see there's only one place where all the holes line up.
I've not see you post in a while. It sounds like your putting things together right now, how is your project going?
John
Mikes442's Avatar
Just asking. When you are bolting up the flex plate are you seeing the counter weight? You need to.
Old Jul 19, 2015 | 01:29 PM
Octania's Avatar
Indeed it has to be right way around and there are two different patterns- 1968+ vs 1967 & back.
Look for the ghost print of the crank notch on your plate for it will guide you to the correct orientation
Old Jul 19, 2015 | 02:04 PM
cutlassefi's Avatar
Originally Posted by Octania
pre-68 vs 67 back
Isn't that the same thing?
Old Jul 19, 2015 | 04:32 PM
Hey 2Blu! I know its been forever! The project is moving along but I hadn't posted pics in a long time. I need to get caught up on here! PS, you're a lifesaver. We got that part all bolted up, but the problem we are stuck at now is that the motor mounts won't let the engine mount up. I am using the original frame mounts but the ones I see online have a notch cut out for the rubber flaps at the top. I had a 455 in the car before, I don't understand the issue. I am using stock replacement engine mounts.
Mike, I CAN see the counterweight, than you very much!
Old Jul 19, 2015 | 04:42 PM
2blu442's Avatar
There have been a few members comment on motor mounts that don't fit. The guru's here suspect its poor quality in manufacturing the parts we're getting from overseas. You can try loosening the bolts that hold it to the engine to see if that gives enough movement to attach the long bolts to the frame pads. Another suggestion is to drill out the bolt holes to an oversize to allow more movement in aligning the bolts.
When you have time give us an update on what all you've done to your car and where you are in the process! John
Old Jul 20, 2015 | 09:45 AM
Octania's Avatar
You making fun of me?
:-) some days are like that.
Fixed it
Motor mounts- in my experience the mismatch is on the order on an inch or so.
One day this got me.
I ended up measuring the frame pads center to center where the thru bolt goes. Now how to measure the motor? The oil pan is in the way.
I hung plumb lines [string and a heavy nut] off the motor mount holes and then measured between strings.
Then went and bought the right mounts.
This was before we had Joe P to gather info from.
This was BEFORE THE INTERNET.
Old Jul 20, 2015 | 12:22 PM
RROLDSX's Avatar
You must be old!😜
Old Jul 21, 2015 | 03:20 PM
Octania's Avatar
Hmmm how kind of you to point that out
Not as old as dirt, but close
My wife is old
but she counters that I am still older
but I proved that she is aging faster than I am.
ha ha ha
Old Jul 21, 2015 | 05:14 PM
RROLDSX's Avatar
First there was the Stone Age, then there was Internet so I just assumed. Besides it takes one to know one.
They don't call me Fred Flintstone for nuthin!
Old Jul 28, 2015 | 09:45 AM
Octania's Avatar
Not one person cares how I proved the princess is aging faster than I am?
Old Jul 28, 2015 | 09:53 AM
It's a slow day Chris so I'll bite. How did you prove the princess is aging faster.
Old Jul 28, 2015 | 10:26 AM
That's easy. YOU'RE causing it (I'm assuming you're drives in the Olds haven't been approaching the speed of light).
The question we want to know is why would you even go there? You have death wish or something?
Old Aug 2, 2015 | 08:08 PM
Octania's Avatar
No, the dynamics of our relathionship allow this sort of banter. she can always fall back on "but you are still OLDER" of course.
The reasoning goes like this
She is about 2y younger than I am.
Therefore, at some point she was about 2 and I was about 4 and I was TWICE as old as her. But, nowadays the difference is more like she is 96% of my age. Therefore she must be aging faster to have caught up from 50% my age to 96% my age.
QED !
csouth
Dec 7, 2012 04:53 AM
real57vetteguy
Aug 8, 2012 07:54 AM
olds455
May 17, 2010 04:43 PM
ctrain22
Jul 10, 2009 08:13 AM
1FSTLS1
May 10, 2008 09:40 AM
