Oil recommendation for an original stock 455
Old Nov 24, 2009 | 01:50 PM
Texas442's Avatar
1971 442 conv
Looking for Engine Oil recommendation (weight and brand) to put in a car that is hardly driven. The car has its original Olds 455 with 79,000 original miles. I only run the car about once every 3 months. Thanks
Old Nov 24, 2009 | 01:59 PM
Gustav455's Avatar
Just because the car has a hydraulic flat tappet cam, i personally use Valvoline VR1 10-30 because it has more ZDDP additives.
Old Nov 24, 2009 | 02:06 PM
I use Rotella T diesel oil.
Old Nov 24, 2009 | 02:12 PM
dc2x4drvr's Avatar
Rotella x2
Old Nov 24, 2009 | 02:27 PM
Dan Wirth's Avatar
For the older car, I would use Redline, Amsoil or Brad Penn 15W-40; Valvoline VR-1 or Rotella, if they are SJ or SL (API) rated.
Old Nov 25, 2009 | 04:29 AM
I like Rotella T because I can buy it pretty cheap at Sam's Club.
Old Nov 25, 2009 | 03:05 PM
MN71W30's Avatar
You guys better do your homework on your oil brands. As far as I've heard the Rotella has eliminated most of the zinc in their oil and things change as the years go by. Oils that were great last year might be lacking zinc now. I have lost several cams over the years and take this very seriously. I reccomend the Valvoline VR with the zinc label on the bottle, Brad Penn or other high zinc oils.
Old Nov 25, 2009 | 10:45 PM
85olds442's Avatar
Thumbs up Oil with Zinc..........
Summit Racing sells their own brand of oil that is made for flat tappet cams, Royal Purple and Lucas also has zinc but a little more expensive. You can find the oil at Checker Auto and at Pep Boys.
Old Nov 26, 2009 | 06:06 AM
I don't know about the zinc additives, I've just heard that Rotella T is a good engine oil. That is why I've put it in my engine since I started it. As long as I change the oil regularly I should be good, I don't drive my car at the track anyways.
Old Nov 26, 2009 | 06:23 AM
citcapp's Avatar
Rotella still has zinc additive although the quantity has been lowered. Its still recommended for flat tappet cams. Check the shell web site its has the information on how much zinc is in their oil
Old Nov 27, 2009 | 04:26 AM
MN71W30's Avatar
From what I've read Rotella after 2007 is below 900 ppm zinc and 1200 to 1400 is reccomended for flat tappet cams. I'm not an expert or pretent to be, and how much of what you read on the subject is BS? . I do know there is a problem out there and I decided to go with a roller cam in my BBC.
Old Nov 27, 2009 | 07:25 AM
Lady72nRob71's Avatar
Here is a good thread for you...
https://classicoldsmobile.com/forums...-car-zddp.html
Given you hardly run the car, any available dino-based 15W-40 diesel oil should be fine for you. If you start driving it more often, CI rated diesel is preferred over the newer CJ. Or use regular oil with a ZDDP additive, or with the other racing oils that has ZDDP (some listed above).
Old Nov 27, 2009 | 07:45 AM
citcapp's Avatar
I went with a roller cams on both my 455's for the hp gain and cam issues of a part time driver.
Old Nov 27, 2009 | 03:42 PM
MN71W30's Avatar
How did I miss that thread, I read through it. It's a subject hit pretty hard. The last 2 cams I lost was from lifters that stopped spinning after several thousand miles and then they get mowed down on one side. Anyone got a clue what caused that?
Old Nov 28, 2009 | 10:21 AM
Nilsson's Avatar
VR1, is rated SH/CD for gasoline and diesel categories.
Best oil for the money ($3.99 quart) imho
Old Nov 28, 2009 | 03:21 PM
Destructor's Avatar
Does VR 1 have deturgents? I only put 1 1/2 quarts in my Cutlass last oil change. Being a racing oil I assumed few or no deturgents, that is not good for street use so I used 3 quarts of conventional oil. If it does indeed have deturgents I'll change the filter and add another quart then go with all VR 1 next oil change.
Old Nov 28, 2009 | 06:43 PM
Nilsson's Avatar
VR1 has less detergents then conventional motor oil. It has only so much less that it is not for extended mileage. Recommended oil change intervals are 3000 miles, I change mine every 2000-2500 miles. I had the valve covers off last winter to paint and everything underneath was absolutely spotless and looked like new.
Now, VR1 "not street legal" has no detergents.
Old Nov 28, 2009 | 07:29 PM
trainfixer2's Avatar
Thumbs up
You can't go wrong with the VR-1 I use it in all my cars even a Triumph Spitfire as well as my 68 455.
Old Nov 29, 2009 | 08:27 AM
Destructor's Avatar
I shall switch to all VR1 and change oil twice a year, about every 1200 miles.
Redog
Oct 20, 2015 03:29 PM
shamusj
May 24, 2015 06:19 AM
69OldZman
Jun 30, 2009 11:47 AM
J'ville
Jul 7, 2006 03:24 PM
