oil galley plug with .040 hole
Isn't it a 3/8" NPT? Hex socket pipe plugs can be found at any good (e.g., not Home Depot or Lowes) hardware store.
What I've done in the past is drill a larger (say, 1/8") pilot hole most of the way through the plug, then punch the hole with the small bit. Bits that small are pretty weak, so drilling all the way through can be a challenge. Especially without a drill press.
ds00469
January 25th, 2014 06:12 PM
