oil galley plug with .040 hole
Old Jan 3, 2017 | 08:03 PM
92banana's Avatar
Hi
Does anyone know where to buy the oil galley plug with .040 hole in for oiling dist. gear?
thanks
Randy
Old Jan 4, 2017 | 06:40 AM
TripDeuces's Avatar
Inline Tube, Mondello, etc.
It's nothing more than a 1/4npt pipe plug with a .040 hole in it if you wanted to go that route
Old Jan 4, 2017 | 10:27 AM
oddball's Avatar
Isn't it a 3/8" NPT? Hex socket pipe plugs can be found at any good (e.g., not Home Depot or Lowes) hardware store.
What I've done in the past is drill a larger (say, 1/8") pilot hole most of the way through the plug, then punch the hole with the small bit. Bits that small are pretty weak, so drilling all the way through can be a challenge. Especially without a drill press.
Old Jan 4, 2017 | 10:53 AM
TripDeuces's Avatar
Senior moment. Yes I think it's 3/8th npt
Old Jan 4, 2017 | 02:04 PM
My442's Avatar
I probably have a spare...want it?
Old Jan 4, 2017 | 05:21 PM
92banana's Avatar
I would love to have it. What do you want?
thanks
Randy
Old Jan 5, 2017 | 06:11 AM
oddball's Avatar
Note that OEM used a 5/16" square drive plug. The appropriate socket is available at Sears, etc.
Old Jan 5, 2017 | 06:49 PM
olds_freak's Avatar
Get a brass one. They're easier to drill.
Old Jan 6, 2017 | 02:49 PM
92banana's Avatar
Thanks for all the replies. Since I did not have the proper bit and my drill press would not close small enough I ordered a drilled plug. Mondello was the only source I could find.
thanks
Randy
ds00469
Jan 25, 2014 05:12 PM
Sean Blake
Dec 3, 2013 09:59 AM
chasman414
May 21, 2012 10:58 AM
knighthawk
Feb 14, 2011 03:28 PM
MN71W30
Jun 28, 2009 12:03 PM
