Oil Fill Tube Numbers?
Old February 27th, 2019, 09:57 AM
takeman's Avatar
What stamped numbers should I have in my 70 455 w30 fill tube? Ive seen quite a few variants and some of the new tubes have no numbers. What should I have?
takeman is offline
Old February 27th, 2019, 04:14 PM
Randy C.
rcorrigan5's Avatar
For a '70 model year, the first number should be a zero. The six digits would represent the engine number.
Randy C.
rcorrigan5 is online now
Old February 27th, 2019, 05:28 PM
scrappie's Avatar
Engine sequence number totally different from V.I.N. number right? This number won't match up to anything correct?
scrappie is offline
Old February 27th, 2019, 05:39 PM
takeman's Avatar
Randy C.
When you say the engine number, what does that mean exactly? I assume not the vin. What engine number should be on there?
takeman is offline
Old February 27th, 2019, 05:54 PM
MOTORHEAD
11971four4two's Avatar
The later in the production year the higher the number will be
just consecutive as they came down the line at the factory I was told
11971four4two is online now
Old February 27th, 2019, 05:58 PM
takeman's Avatar
Any idea where the numbers fell month wise? Or the range of numbers from beginning to the end of the 70 model year?
takeman is offline
Old February 27th, 2019, 07:06 PM
Randy C.
rcorrigan5's Avatar
What 11971four4two said. The engine number has no relationship to the VIN. I don't have any idea of where the engine numbers fell month-wise. And I don't know if it has any relationship, but the number on my '68 (first week of April '68 build) is 8429570 and the number on my '69 (third week of May '69 build) is 9564351. Hopefully, people with '70 model year cars will chime in. If you provide the build date of your car, that might help. I don't know if the engine sequence number is in disregard to engine size (350 of different horsepowers, 455 of the different horsepowers, W30 455) or if each engine size is sequenced separately.
Randy C.
Old February 28th, 2019, 08:53 AM
Gary
VC455's Avatar
My 1970 Vista L-31 (455, 4-bbl) built in Lansing about Jan 07 has number 0302134.
Seems like a very low number for an engine that was standard on every 98, but the tube had matching factory blue paint when I bought the car 36 years ago from people who were definitely non-car enthusiasts (suburban family that used it as a tow vehicle for their boat and to go to the shopping mall).
Long way of saying that it is very likely that the tube was original.
VC455 is online now
Old January 2nd, 2020, 04:53 PM
4Speedy's Avatar
Originally Posted by VC455
My 1970 Vista L-31 (455, 4-bbl) built in Lansing about Jan 07 has number 0302134..
my 70 442 build date Jan 26th has a
tube number of 0339917 sounds you're right on with the tube sequence number.
4Speedy is offline
70W-32
August 31st, 2017 04:24 PM
dean333
September 5th, 2014 10:26 AM
Doomah
May 16th, 2014 05:07 AM
pfergy600
September 28th, 2013 07:47 PM
72old$
July 23rd, 2011 08:09 PM
Quick Reply: Oil Fill Tube Numbers?
