Offenhauser Dual Quad with a MSD Distributor?
Old Dec 11, 2025 | 07:07 PM
1970Olds442's Avatar
I've searched this site and I can't find a definite answer to my question, so I'm hoping someone can help. I have an Offenhauser dual quad manifold I want to put on my 455 with a Terminator X EFI 2x4 with 4150's. I know the Offy isn't a good intake but I'd like to play around with dual quads and I always have the option to go back to a single 4 barrel if I find I just don't like it.
My question is, can I use my MSD distributer (part 8566) with the Offy dual quad manifold? I keep seeing mixed answers due to fitment, anywhere from "absolutely not, it won’t fit" to "yes, HEI will fit but not one with a 'large' cap". There's even a post on this site where someone is using the same Offy intake with an MSD Ready To Run distributer on an EFI application. The Olds MSD RTR has almost the exact same measurements as the 8566, so it sounds like it should.
Any information would be appreciated, thanks!!
Ray
Old Dec 11, 2025 | 08:05 PM
EarlSpilner's Avatar
I have run the offy low rase dual 4 intake for several years with edelbrock carbs and a msd ready to run. That setup fits no problem. I suspect you'd do fine with a stock none-hei sized distributor
Honestly I say just give it a try. FAFO. Post the results
Old Dec 12, 2025 | 04:00 AM
JerryW's Avatar
During our dyno testing we used a MSD pro billet distributor and it fit with every intake we have tested.
jerry
Old Dec 12, 2025 | 09:55 PM
Thanks for the replies, sounds like I'm going to be OK! This build is going to take a while, but I'll post some results once we get everything figured out, there's a lot going on along with the Terminator X 2x4 (aluminum heads, headers, and a few other things).
Ray
zl1 camaro
Sep 29, 2023 04:26 AM
Crankit
Nov 30, 2022 07:47 PM
Amplitude
Jan 19, 2022 08:37 AM
GEARMAN69
Apr 17, 2015 06:17 AM
silverriff
Jul 12, 2008 08:43 AM
