notched pistons
Old Jul 13, 2008 | 12:43 AM
geckonz08's Avatar
notched pistons
Today I removed the heads (B) from a 425 toro engine .Can someone advise me please
a. if oversize pistons are also notched also
b. are these notched (small v) pistons original or could these also be aftermarket ?/
cheers
mike
Old Jul 13, 2008 | 03:11 PM
442Harv's Avatar
Those are stock pistons. Most pistons that are oversized, have the over size stamped on them like .030. The notch goes to the front off the engine.
Old Jul 13, 2008 | 03:12 PM
Warhead's Avatar
Edited...I thought you were talking about valve notches...
Old Jul 13, 2008 | 07:23 PM
geckonz08's Avatar
thanks 442 harv.That means without having done a bore measurement ,I have more room to play with .Looks as though I may need that room .Pulled the sump and there was roughly 3 litres of emulsified oil/water and right at the sump plug, when laid out was a handful of metal particles fom say 3 mm to 8 mm --very ugly .The engine is seized --surprise surprise but the bores which I can see have no scoring or even lip at the top.--just a bit o carbon .Will post some pics of this ugliness when I can
cheers
mike
Old Jul 18, 2008 | 03:00 PM
geckonz08's Avatar
pic of block as being stripped --now unseized after a night in kerosene -enough grease on here to compete with athabasca tar sands .
Crank looks great bar #6 which has a series of small grooves on it .
Be looking for new valves ,cam n all top end stuff as some point
Old Jul 18, 2008 | 04:45 PM
citcapp's Avatar
Looks like it came out of the same tar pits as the dinosaurs. Good luck
scott_442
Jun 14, 2011 06:58 PM
veltboy618
Aug 25, 2010 12:50 PM
MN71W30
Apr 28, 2009 04:50 AM
MN71W30
Apr 26, 2009 07:48 PM
