notched pistons
notched pistons
Today I removed the heads (B) from a 425 toro engine .Can someone advise me please
a. if oversize pistons are also notched also
b. are these notched (small v) pistons original or could these also be aftermarket ?/
cheers
mike
cheers
mike
thanks 442 harv.That means without having done a bore measurement ,I have more room to play with .Looks as though I may need that room .Pulled the sump and there was roughly 3 litres of emulsified oil/water and right at the sump plug, when laid out was a handful of metal particles fom say 3 mm to 8 mm --very ugly .The engine is seized --surprise surprise but the bores which I can see have no scoring or even lip at the top.--just a bit o carbon .Will post some pics of this ugliness when I can
cheers
mike
cheers
mike
pic of block as being stripped --now unseized after a night in kerosene -enough grease on here to compete with athabasca tar sands .
Crank looks great bar #6 which has a series of small grooves on it .
Be looking for new valves ,cam n all top end stuff as some point
