Newbie 68 455 re build
Hello all, I am hoping to get some help on my piston and head selection for my 455. I am going to have a shop do the short block but I want to make sure I get the most bang for the buck.
My goal is a good cruisin car with good power. Not doing any drag racing but I want a car that does back up the 455 name plate.
Here is the pistons and heads I have been looking at:
http://www.summitracing.com/parts/UEM-IC886-040/
http://www.summitracing.com/parts/EDL-60529/
Thanks again!
Thanks again!
This is the description I get when I click the link
BrandEdelbrock
Manufacturer's Part Number60529
Part TypeCylinder Heads
Product LineEdelbrock Performer RPM Cylinder Heads
Summit Racing Part Number: EDL-60529
Cylinder Head Style: Bare
Cylinder Head Material: Aluminum
Cylinder Head Finish: Natural
Combustion Chamber Volume (cc): 77CNC-Machined Combustion Chamber: No
Intake Runner Volume (cc)188cc
Exhaust Runner Volume (cc):106cc CNC-Machined Intake Runner No
CNC-Machined Exhaust Runner: No
Intake Port Location: Standard
Exhaust Port Shape: Square
Exhaust Port Location: Standard
Intake Valves Included No
Intake Valve Diameter (in): 2.072 in.
Exhaust Valves Included: No
Exhaust Valve Diameter (in): 1.680 in.
Valve Springs Included: No
Damper Spring Included: No
Retainers Included: No
Locks Included: No
Valve Stem Seals Included: No
Rocker Arm Studs Included: No
Rocker Arms Included: No
Rocker Arm Nuts Included: No
Guideplates Included: No
Accessory Bolt Holes Drilled: No
Valve Guides Included: Yes
Valve Guide Material: Manganese bronze
Valve Seats Machined: Yes
Valve Seat Machine Style: 3-angle
Valve Seat Material: Ductile iron
Steam Holes Drilled: No
Oiling Style: Through pushrod
Machined for O-Ring: No
Heat Crossover: No
Quantity Sold individually.
BrandEdelbrock
Locks Included: No
Heat Crossover: No
OK the picture shows a Crysler head, who cares, the point isn't if Summit Racing has thier web page perfect.
http://www.summitracing.com/parts/EDL-605119
That is the link to the assembled
<LI class=pdetail>Cylinder Head, Performer RPM, Aluminum, Assembled, 77cc Chamber, 188cc Intake Runner, Oldsmobile, 350-455
Are you sure you want to drop the $$ on the edelbrock heads? Keep in mind the price listed on summit is PER HEAD, not for a pair. If you're not going to be racing I don't think it's necessary. There are a few guys on here who have either solid stock cores or complete heads that would be a bolt-and-go option. Unless you want to be making more than 450-500 hp the aluminum heads aren't necessary. What are your goals for this motor? How much power, how high do you want to spin it, etc? I think Mongoose also has a set of nice, ready to run, complete big valve C heads and port matched intake he'd be willing to part with. Check with him or gearhead78. JMO, but I'd say go that route and spend the money you'll save on other parts.
Here is the link. I also have a set of new .030 TRW's for $300.00 more if you buy these. Also have a BHJ balancer too
https://classicoldsmobile.com/forums...0-sec-car.html
wildwillie1981
Apr 24, 2013 04:19 PM
