New radiator
Old Oct 4, 2011 | 04:51 PM
67Olds442X2's Avatar
Navy P-3 FE (Ret.)
New radiator
Got a Griffin radiator which will hopefully keep the temps down. Looks like my original shroud will fit without a hitch. Had to remove the original brackets and use ones for the new radiator. Upper brackets held by bolts until I get them welded.
Old Oct 4, 2011 | 05:44 PM
Aron Nance's Avatar
Congratulations on the new aluminum radiator! I had a new one installed about 2 years ago, and it took care of my "HOT" problems RIGHT NOW!
Old Oct 4, 2011 | 10:22 PM
ah64pilot's Avatar
That's so purty Dan! Don't forget to run distilled water...I don't care what others say, it's not very acidic and will take a lot longer to ruin a radiator than the calcium in tap water. And if you ever plan on running the aluminum heads you might as well start running dexcool in it now
Old Oct 5, 2011 | 10:59 AM
455man's Avatar
Are those the horns mounted beside the radiator? To increase airflow to the radiator? Give me an idea for my hot motor...
Old Oct 7, 2011 | 05:16 PM
Navy P-3 FE (Ret.)
The radiator works well, temp stays below 180. Usually 160-170.
http://www.summitracing.com/parts/GRI-8-70008/
Alex72cutty
Apr 21, 2015 10:30 AM
59Olds98
Aug 14, 2013 09:38 AM
g77rvd
May 13, 2011 11:29 AM
Lazlobassett
Mar 8, 2008 04:40 PM
tiparosa
Feb 19, 2007 06:14 PM
