New radiator
New radiator
Got a Griffin radiator which will hopefully keep the temps down. Looks like my original shroud will fit without a hitch. Had to remove the original brackets and use ones for the new radiator. Upper brackets held by bolts until I get them welded.
That's so purty Dan! Don't forget to run distilled water...I don't care what others say, it's not very acidic and will take a lot longer to ruin a radiator than the calcium in tap water. And if you ever plan on running the aluminum heads you might as well start running dexcool in it now
The radiator works well, temp stays below 180. Usually 160-170.
http://www.summitracing.com/parts/GRI-8-70008/
Alex72cutty
Apr 21, 2015 10:30 AM
