New Problem with my dad's 70 delta 88
Old Jan 2, 2010 | 11:15 PM
Prsabordo's Avatar
Hey everyone, my dad took his car to work the other day and when he came back he told us it was backfiring. We didn't believe him until we took it for a cruise today. On the way home i was accelerating steadily and sure enough, it hesitated but i let off before it could backfire. I was thinking the fuel pump is going bad or the carburetor needs adjustment. Any ideas?
Old Jan 3, 2010 | 06:04 AM
70 cutlass s's Avatar
More than likely just a tune up. If that doesn't work than it might need a pick up coil in the dist. or carb. rebuild.
Old Jan 3, 2010 | 06:45 AM
rwlarson's Avatar
First make sure it's a "backfire" through the carb and not a "muffler explosion" out the exhaust. It makes a big difference in where you start to look. Go ahead and make it "backfire" for yourself to be sure. Rich
Old Jan 3, 2010 | 06:53 AM
Oldsguy's Avatar
Past Administrator
Make sure the distributor hasn't slipped, sounds like timing.
moved to new forum....
Old Jan 3, 2010 | 07:13 AM
Oldsguy makes a good point start with checking your timing first.
Old Jan 3, 2010 | 07:36 AM
BIGJERR's Avatar
I bleed Oldsmobile
That old nylon coated timing chain may of jumped ship also!
Old Jan 3, 2010 | 08:35 AM
Lady72nRob71's Avatar
Check for vacuum leaks, too, such as broken hoses.
Old Jan 3, 2010 | 11:08 AM
Prsabordo's Avatar
Dang, sounds like we got a lot of little jobs to do today. Alright i'll be sure to check these off our list and i'll update when i'm finished. when my dad drove it to work he was going freeway speed and it backfired in the exhaust but when i drove it the other day it sounded like it was in the carb.
Old Jan 3, 2010 | 02:46 PM
rocketraider's Avatar
Oldsdruid
Keep it simple. A cracked or carbon-tracked distributor cap or a bad condenser (points ignition) are the simplest places to look, especially if the problem started suddenly. If those check out, then you dig deeper.
Perkolator
Jul 17, 2015 01:13 PM
dejjo22
Aug 2, 2014 01:23 AM
Youngoldslover
Cars Wanted
Nov 7, 2013 02:44 PM
.Rocket.Man.
Dec 26, 2011 11:07 PM
Pitbull2o08
Jan 16, 2008 07:38 PM
