new intake
Old Mar 17, 2009 | 04:50 AM
70_CS's Avatar
torque machine
Talking new intake
here is the intake im putting on the 455 going into my torque machine tell me what you think.
1500-6500rpm
Old Mar 17, 2009 | 06:07 PM
cutlassefi's Avatar
New intake
I like it. Professional products right? What are your engine specs?
Old Mar 18, 2009 | 06:09 AM
70_CS's Avatar
torque machine
455 bored 30 over with big valve c heads fresh stock internals, magnum muscle 280h comp cam, 1442-kit comp cams valve train kit, matching comp cam springs, im still looking for a hei distributer and a carb but yea she will scream lol
70_CS's Avatar
torque machine
oh yea its professional products its called the crosswind
Old Mar 20, 2009 | 04:56 AM
cutlassefi's Avatar
Manifold
Sounds lie a nice combo except for the cam. You might want to think about using a dual pattern one as even ported Olds exhaust ports aren't the most efficient. Just a thought.
Old Mar 20, 2009 | 06:49 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Did you buy it yet?
We did back to back testing at the track using an edelbrock Performer, and a Crosswind.
The crosswind wasn't any better than a regular old Performer.
Old Mar 20, 2009 | 07:22 AM
70_CS's Avatar
torque machine
yea i got it maybe it will work better for me lol
Old Mar 20, 2009 | 07:28 AM
hamm36's Avatar
How does that compare to the Ed. Performer in price and performance?
Is that a square bore the Holley will fit with out an adapter plate? (am I getting my terminology wrong?)
Sorry J-C, I guess I should read all the post, before posting.
Old Mar 20, 2009 | 07:35 AM
70_CS's Avatar
torque machine
yes it will fit a holley i got the holley 770 street avenger and it fits right on. the edlebrock os a lil cheaper but i read its more for top end where the crosswind is more torque
Old Mar 20, 2009 | 11:23 PM
88 coupe's Avatar
Junior Member
Originally Posted by J-(Chicago)
........ We did back to back testing at the track ........
Were both setups optimized (advance, jets, etc) for that application? Were the air density (altitude) numbers corrected?
Norm
Old Mar 20, 2009 | 11:40 PM
88 coupe's Avatar
Junior Member
........ even ported Olds exhaust ports aren't the most efficient ........
Not when measured on a flow bench.
In a running engine, there is a big pressure (higher pressure = higher flow) difference between the intake and the exhaust. Only one of many factors involved in a cam choice.
But I have never "talked" to any big name cam grinders or engine builders, and I do not work in a machine shop.
Norm
Old Mar 21, 2009 | 12:33 PM
trdbrd's Avatar
I used this same intake on the 455 I built for my 64. It feels plenty pucnchy off the bottom with a nice linear powerband up to 5800 or so. Im using a Mondello 22-25 cam with it and running about 9.7-1 compression. I have a torker to try later if I want but so far im happy with it.
Wildcard
Dec 26, 2012 07:48 AM
Nickyloves442s
Oct 24, 2012 04:55 PM
svnt442
Jul 17, 2011 04:43 PM
71cuttyS
Oct 31, 2007 04:58 PM
