need help with pistons
Old May 20, 2013 | 06:58 PM
SavedbyHim's Avatar
I have a 1961 super 88 with the 394 10 to 1 high compression engine. I am rebuilding it, and ordered new .030 over pistons. They came today, but, they are dished and have valve reliefs cut in the top. Is this so to compensate for the .030 over, or did they send me the wrong ones. they said they were for the four barrel carb.
Old May 20, 2013 | 09:01 PM
Erinyes's Avatar
Don't know about the 394, but the 425 pistons are dished for both the 9 to 1 and the 10.25 to 1 ratios - just not by the same amount. It wouldn't surprise me that the 394 was designed the same way.
Old May 21, 2013 | 11:13 AM
SavedbyHim's Avatar
My stock pistons are true flat tops. I am having a very hard time finding any true 10 to 1 flat tops anywhere. Everyone says they are no longer available.
Old May 21, 2013 | 11:28 AM
59-59-59's Avatar
Everyone didn't try Ross Racing or Egge
Old May 22, 2013 | 06:01 AM
SavedbyHim's Avatar
Yep, they dont have the high compression ones, only the low compression for a 1961.
Old May 22, 2013 | 06:07 AM
cutlassefi's Avatar
What is the compression distance and pin size?
Old May 22, 2013 | 06:15 AM
SavedbyHim's Avatar
I found some at Kanter, but now, I am not sure if I want to just run the dished ones I have.
Old May 22, 2013 | 06:23 AM
cutlassefi's Avatar
I have the bore size but can't find compression distance or pin size. Got anything on that?
I'll bet you can find a piston that'll work without a bunch of difficulty.
Old May 28, 2013 | 06:18 PM
Ross Racing Engines's Avatar
You couldnt have tried us.....we do everything from dish....flattop or domes.
Tony
Al2011
Aug 24, 2011 06:58 PM
getawaycar
Jul 13, 2011 05:13 AM
oldzy
Oct 26, 2010 05:35 PM
0590trab
Mar 29, 2009 06:47 AM
cts-v
Jan 22, 2009 12:44 AM
