Need cam selection help
Old Oct 30, 2012 | 03:13 PM
lonestarjarhead's Avatar
Does anyone have any suggestions or results with a mild cam for a mostly stock 455 that I'm building to go in my 63 88 convertible? Not interested in racing or anything like that, just a little more power besides what a new manifold and carb will give me. Thanks.
Old Oct 30, 2012 | 03:57 PM
cutlassefi's Avatar
Compression, gear, tranny? That would help to start with.
Old Oct 30, 2012 | 05:06 PM
oldstata's Avatar
Justin
I don't know the answers .just wanted to join this thread as I am looking for the same thing mine is a 71 455 and will have a th400 behind it in a 65 cutlasd
Old Oct 30, 2012 | 05:24 PM
cutlassefi's Avatar
Need the gear ratio if you can get it.
Old Oct 30, 2012 | 05:28 PM
oldstata's Avatar
Justin
I am not positive on the rear gear .it should be 3.23 I believe from research ,but when I lifted it up I spun tire once and drive line turned 1.5 so I think it might be a 3.08 but I do want to put a posi in it and maybe go up / down in gearing
Also I will be replacing torque converter as well
Old Oct 30, 2012 | 06:22 PM
cutlassefi's Avatar
I do a 214/214 on a 110 with .472 lift. That would work well with stock compression and manifolds.
Old Oct 30, 2012 | 09:47 PM
Intragration's Avatar
Just out of curiosity Cutlassfi, how noticeable would a cam like that be in a mostly stock motor, things like idle and vacuum?
Old Oct 31, 2012 | 05:14 AM
Need help
I'm wanting a street engine, so using a 71 455 with TH400. Engine is stock, with new rings, bearings,etc. Will run Edelbrock Performer with QJet carb, if it will fit under the hood. Think compression is 8.5:1 and stock rear end is probably 2.56 or 2.87.
cutlassefi's Avatar
In a small block you might hear it a little with a nearly stock idle.
In a big block it would be almost unnoticeable but with low compression your goal is to build cylinder pressure first. This would be a good cam for that.
Old Nov 6, 2012 | 07:31 PM
jfb's Avatar
jfb
jm 16 18 by mondello and engle call them for perfection in your application.
Old Nov 6, 2012 | 08:00 PM
Rickman48's Avatar
Yeaah - call Mondello and ask them, Maybe they'll sell you solid lifters on a hydraulic cam and say it's "high performance, just adjust zero lash"!!
Read some of the threads about them!!
I'd not recommend them for windshield wipers, as they'd screw that up, and want shipping both ways - STAY FAR AWAY!!
Old Nov 7, 2012 | 08:40 AM
70Wcars's Avatar
I built a 350 some years back for a friend. That motor was .030 over with replacement cast pistons, stock heads and intake with dual exhaust and one of my blueprinted Q-jets. I used the cam Cutlassefi is talking about...that motor ran very well with 2.73 rear-end. 350 has now been transplanted to a 70 convert and the new owner is claiming 18mpg at cruise and it still spins the tires at start. I think 3.08, but not sure. One thing we did with that build was a .020 deck of block to get the replacement pistons closer to zero deck.
Bottom line I like the 214/214 Erson Cam. Not a noticeable change in idle quality, but again I am very careful with my calibartion of the Q-jets I build.
Just my experience.
Danny
Nickyloves442s
Dec 1, 2014 11:18 PM
timholliday
Oct 24, 2014 08:39 PM
78cutlass
Sep 11, 2011 05:24 PM
ijasond
May 13, 2008 08:27 AM
bobolds
Mar 26, 2007 02:45 PM
