Mr Gasket Ultra-Seal -- Which One?
Old Jun 15, 2017 | 12:40 PM
gbledsoe3's Avatar
Part #: 6112G - $329.95 Includes MLS Head Gaskets
Part #: 5981MRG - $191.95 Standdard Ultra-Seal Head Gasket
Old Jun 15, 2017 | 01:06 PM
cutlassefi's Avatar
They've recently changed the front cover seal though and it's wrong.
Old Jun 15, 2017 | 02:40 PM
gbledsoe3's Avatar
So, now what? Buy the cheaper Mr. Gasket set, source Cometic MLS head gaskets and source the front cover seal/gasket from somewhere else? I see Fusick has a front cover set for $29.50 which includes the front cover, water pump, damper seal, oil pan seal and fuel pump gasket.
BTW- By my calculations, a Cometic with .027" compressed thickness (4.200" bore) will figure to 10.00-to-1 CR.
NOTE: I need to cc a cylinder heard to verify the 77cc value.
Old Jun 15, 2017 | 03:30 PM
cutlassefi's Avatar
If you're .008 in the hole with a 77cc chamber then you'll have at least 10.0:1 even with a .038 thick gasket. The dish on those pistons is 14.5, not 18.
And just get the Ultra seal kit and buy a front cover seal for $5.00. I just mentioned it so you knew when you got it that it's been like that.
Old Jun 15, 2017 | 04:35 PM
gbledsoe3's Avatar
The Ultra-Seal kit with the MLS head gaskets? (aka $330)
Old Jun 16, 2017 | 09:52 AM
cutlassefi's Avatar
No, the one I did in bold.
Old Jun 17, 2017 | 07:59 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Thank makes sense, sure it saved them 5 cents. The conversion set is a cheap addition and has the right front seal. https://www.summitracing.com/parts/FEL-CS8171-2
Brezzi
Mar 23, 2011 08:05 AM
agtw31
Sep 3, 2010 11:57 AM
Big D's Blue 04
Aug 13, 2009 10:49 AM
bobsrats
Apr 2, 2009 07:36 AM
Sixoh
Aug 8, 2006 05:11 AM
