Motor mounts
Motor mounts
I recently replaced my motor mounts with some auto zone mounts and seems like my motor shakes at idle now is anyone else using the mounts from auto zone or what are good mounts to use car is a 1970 442 with 455 small cam stock wheels and tires not a race car just a cruiser
thanks man the very rear plug wire was almost off the cap pushed it down on the post good to go thank you
Joe, would you replace motor mounts with what is available today on a ‘70 Cutlass 350 c.i. 4-barrel as preventative maintenance if the original motor mounts aren’t broken?
I wouldn't replace them unless you can see cracks in the rubber. It's the driver's side that's under tension load, and the easy test here is to rev the motor with the trans in drive while someone is watching the motor. If the engine lifts excessively, replace the mounts. Otherwise, it's not really necessary.
