Motor mounts
Old Jan 11, 2023 | 12:28 PM
Gene kerr's Avatar
Motor mounts
I recently replaced my motor mounts with some auto zone mounts and seems like my motor shakes at idle now is anyone else using the mounts from auto zone or what are good mounts to use car is a 1970 442 with 455 small cam stock wheels and tires not a race car just a cruiser
Old Jan 11, 2023 | 12:42 PM
Look for a spark plug wire that got knocked loose when you changed the mounts. Auto zone sells the same imported mounts that everyone else sells. The correct mounts would have been 2328 style
Old Jan 11, 2023 | 01:22 PM
CANADIANOLDS's Avatar
Are they Anchor brand mounts?
Old Jan 11, 2023 | 01:29 PM
From AutoZone they are probably Duralast brand, made in the same Chinesium factory as Anchor. That still isn't going to make the motor vibrate.
The reason the engine shakes is due to a misfire, not the mounts.
Old Jan 11, 2023 | 02:00 PM
Gene kerr's Avatar
thanks man the very rear plug wire was almost off the cap pushed it down on the post good to go thank you
Old Jan 11, 2023 | 02:07 PM
Sometimes it's the smallest things...
Old Jan 12, 2023 | 03:03 PM
these Chinese ones that are $10 will rip apart with modest power increases.
Old Jan 12, 2023 | 03:09 PM
And yet, still not the cause of this misfire-induced vibration.
Old Jan 12, 2023 | 03:24 PM
ya, imagine having to go online to find out you knocked off one of your plug wires?
Old Jan 19, 2023 | 09:02 PM
Toms cutlass's Avatar
Joe, would you replace motor mounts with what is available today on a ‘70 Cutlass 350 c.i. 4-barrel as preventative maintenance if the original motor mounts aren’t broken?
Old Jan 20, 2023 | 06:15 AM
I wouldn't replace them unless you can see cracks in the rubber. It's the driver's side that's under tension load, and the easy test here is to rev the motor with the trans in drive while someone is watching the motor. If the engine lifts excessively, replace the mounts. Otherwise, it's not really necessary.
Old Jan 20, 2023 | 07:21 AM
Thanks, as always, for your expertise Joe.
Gene kerr
Dec 30, 2021 09:01 AM
ergot71
Feb 18, 2020 05:38 AM
74 fastback
Oct 5, 2015 05:29 PM
madmax442
Apr 14, 2015 05:46 PM
csouth
Apr 10, 2012 02:19 PM
