Moroso vs Milodon 7 Quart Oil Pan
Old Jul 26, 2016 | 09:16 AM
VinMichael's Avatar
Wondering if any of you have an opinion of which oil pan is a better fit and quality. My car is a 64 Cutlass and I was leaning more toward a Milodon for my 455 but I have the opportunity to get a good deal on a Moroso. I'm in the market for a 7 quart capacity. Thanks
Old Jul 26, 2016 | 11:19 AM
70cutty's Avatar
Beer Connoisseur
Get a Rocket Racing pan, pickup and gasket. Best quality IMO.
I've had issues with Milodon and I know guys had problems with Moroso too.
Old Jul 26, 2016 | 12:54 PM
My442's Avatar
Milodon pans are thin, with mediocre welds.
I had one of their pick up tubes fail (poor weld) that cost me an engine rebuild.
Caveat Emptor.
Old Jul 26, 2016 | 04:06 PM
cutlassefi's Avatar
Had some problems awhile back with the Moroso pans. However used a few lately with no issues.
Old Jul 28, 2016 | 06:57 AM
I wanted to put a Moroso pan on my 455 and put one on it when the engine was on the stand. It leaked. I contacted Summit and they let me swap for another one. It leaked on the stand too. So, I sent the 2nd one back and got credit towards a Milodon pan. It didn't leak!
Old Jul 29, 2016 | 06:48 AM
oddball's Avatar
I ran an OPP 7qt pan. The rails were warped like most modified pans, although Andy swears up and down that his are the only ones that get built perfectly. It bolted up and sealed find though.
The welds were quite strong! I eventually broke the back weld after landing on the oil pan for the 10th time or so. Turns out a deep pan + >3" lowered front + medium-soft shocks = broke pan. Who knew?
Old Mar 12, 2017 | 11:56 PM
Beamin23's Avatar
hows the clearance will it hang low past the crossmember on a 72 cutlass and u have u use it do u have any pics ?
Old Mar 13, 2017 | 08:42 AM
csouth's Avatar
Canton Racing pan with trap door baffles...
Old Mar 13, 2017 | 03:54 PM
AK71CutlassS's Avatar
I have a milodon on mine. Hopefully it doesn't leak when I run it:/
Old Mar 13, 2017 | 08:40 PM
Still building engine. But looked down at the pan around rear part of crank. Gasket is wet and had some fresh oil to be there. Looks like the seal absorbed it. Hopefully this won't be an issue when I run it:/
Old Mar 14, 2017 | 09:43 PM
So the verdict is RR pans? I'm curious of this as well
Old Mar 14, 2017 | 09:57 PM
VinMichael's Avatar
I might go for the RR pan and pickup. Never came through with the Moroso
Old Mar 14, 2017 | 10:15 PM
I'm thinking of dumping my milodon pan and pickup before I run into any issues. It's just money
Old Mar 14, 2017 | 10:38 PM
VinMichael's Avatar
If it's leaking now dump it. Imagine when the oil gets hot.
You might be able to get a refund.
Old Mar 14, 2017 | 10:42 PM
Not sure I have the box for it. I'm curious what the RR pan looks like
Old Mar 14, 2017 | 10:46 PM
VinMichael's Avatar
I'm not sure who actually has the RR piece
Old Mar 17, 2017 | 10:24 PM
Might try and reseal the milodon. What Pn Gasket is. Eat
Old Mar 21, 2017 | 11:20 PM
I ended up ordering the RR pan. I'll post a pic when I get it. Any tips on sealing these pans ?
Old Mar 22, 2017 | 07:35 AM
oddball's Avatar
The Felpro kit for the diesel - OS30471C - is a steel core with cork for the rails. Very good set. I still use a spray gasket maker on both sides of the rail gaskets, dabs of silicone on the ends of the rubber seals and where the rubber meets the rails, that's it.
Moroso also makes a nice kit, but don't believe it when they say it's "tear proof". It'll tear if you just yank it our of the packaging.
Old Mar 22, 2017 | 12:29 PM
VinMichael's Avatar
Awesome. Please do post pics of the setup.
Old Apr 3, 2017 | 02:15 PM
Just got rocket racing pan. It appears to be built a lot better than the milodon. Looks like a winner!!
Old Apr 3, 2017 | 04:30 PM
cutlassefi's Avatar
That's what I've started to use, nice piece.
Old Apr 3, 2017 | 04:36 PM
Old Apr 10, 2017 | 02:36 PM
No luck on second attempt with rocket racing pan and there seals. Put Rtv in the four corners where the gasket overlaps the rubber seal. It's leaking from the right rear bolt see pic
Old Apr 10, 2017 | 05:42 PM
This is the same thing that happened to milodon. Maybe RR is made by Milodon. Gunna call and check tomorrow with rocket racing on Return. On to Canton once I hopefully get this returned.
Old Apr 11, 2017 | 12:57 AM
Gunna give permatex on each side a try. Will let u know how it goes
Old Apr 12, 2017 | 07:25 AM
oddball's Avatar
Looks like the gasket was installed incorrectly. There must be a blob of RTV between the rubber seal and the block where the cap meets the block. The rubber seal has some indentations on the underside to hold RTV. I put a pea sized dollop in the cavity between the cap and the block where the seal slips in, plus a very small layer on the step on the block where the flap of the seal lands. Then another small bit where the side gasket lays on top of the rubber seal. Same on both sides on the rear.
Similar with the front - RTV provides the seal between the side gasket, rubber gasket, block and timing cover.
Qwik71442
Mar 9, 2016 08:43 PM
gunmetal71
Jul 10, 2015 03:49 PM
70cutty
Jun 24, 2015 03:29 AM
brandon 455
Mar 29, 2014 01:49 PM
QS442
Oct 6, 2013 08:21 PM
