Mixing new ARP head bolts w/ original ACC stud headbolts ok?
Old Feb 18, 2013 | 04:56 PM
RAMBOW's Avatar
Ben
Did some searching and didn't see an obvious answer...
I bought all new ARP headbolts for my 455 build- but my car has the power steering on the drivers side and there a headbolt with a stud on top that the PS bracket attaches to. I don't see that ARP makes a bolt like that.
I have an extra original ACC studded head bolt- can i just it with the stock recommended torque spec (oiled) in conjunction wtih the rest of the ARP bolts, being greased and torqued to the ARP spec? or is that a big no-no?
Thanks-
Ben
Old Feb 18, 2013 | 08:30 PM
Just curious on the difference in torque spec between the ARP bolt and stock. If it's not much I would use the stock stud at ARP torque spec's.
Old Feb 18, 2013 | 11:52 PM
RAMBOW's Avatar
Ben
I went ahead and lubed & installed all the ARP bolts torqued to spec. I'll decide later on if I want to pull that one out and replace it with the stock stud bolt.
ARP's spec on these w/ their required moly lube is 70ft/lbs
Stock head bolts spec dipped in oil is 80ft/lbs
Old Feb 19, 2013 | 04:25 AM
I have a ARP head bolt with the stud for A/C or alternator brackets. I cant recall where I got it but it is available. I'm not using it, if you cant locate one let me know.
Old May 24, 2017 | 12:40 PM
gbledsoe3's Avatar
Realizing this is old but folks are still actively posting. What did you end up doing for the cylinder head bolts that need to be studs for the power steering pump bracket mounting?
I'm ready to tackle that issue now. I bought the ARP 180-3600 head bolt kit and just drug out my ps bracket and media blasted them.
Old May 25, 2017 | 05:21 AM
Gary, I bought a sat of ARP head bolts for my 455 and used the stock bolts w/ stud where necessary. I believe there is one bolt w/ stud on each side (one for PS and one for AC). Interestingly, I used the Oldsmobile torque spec and not the ARP spec.
Old May 25, 2017 | 07:08 AM
gbledsoe3's Avatar
Just a thought, if one were to use the ARP head studs instead, is there enough 'stud' above the nut to attached either the PS or AC bracket?
Old May 25, 2017 | 07:22 AM
I doubt it. Head studs are intended to replace head bolts and provide more clamping force. They're generally used in racing applications (where a PS pump and AC wouldn't be used), or on engines that were poorly designed from the factory that blow head gaskets all the time (like the Ford 6.0L diesel or the Cadillac 4.6L Northstar).
Old May 25, 2017 | 10:32 AM
83hurstguy's Avatar
If you use the ARP head bolts, use the stock torque spec with their lube. There has been a history of leaky head gaskets using the reduced torques.
Reference this thread for more info:
http://realoldspower.prophpbb.com/topic812.html
Old May 25, 2017 | 10:45 AM
Good to know, thanks Luke.
Old May 25, 2017 | 04:58 PM
gbledsoe3's Avatar
Found my original head bolts. A little time in the media blast cabinet and using the wire brush on the bench grinder and they look good as new. I'll only use the ones with the stud though.
Old May 26, 2017 | 05:19 AM
Man, I need to get a media blaster and cabinet. Those look brand new!
Old May 26, 2017 | 07:09 AM
ELY442's Avatar
Im using ARP head studs #185-4001 that takes a torque to 80lbs with their moly lube and using the stock head bolt with studs and torque it to 80 lbs. No problems so far.
Old May 27, 2017 | 06:11 AM
gbledsoe3's Avatar
To be honest, it was the wire brush wheel on my bench grinder that put the "shine" on them. After the media blasting, they're clean but a dull gray. Besides I needed to make sure the threads were cleaned of any left over blast media.
EightballZ
Mar 24, 2014 05:03 PM
ohiocutlassparts
Jan 15, 2014 04:36 PM
jensenracing77
Jan 16, 2013 03:12 PM
Stevec
Aug 4, 2012 06:52 PM
Al2011
Apr 19, 2012 10:56 AM
