Misc. Questions regarding 66' Delta 88
Two things...
First,
That curved oil fill tube was a '68 w/AC only version. Point is that may not be the original 425 engine, rather a '68 400 or 455. What are the block casting #'s between the water pump and the thermostat housing?
Second,
Does it just have a noise in the engine or was it diagnosed/confirmed to be a connecting rod? Check for loose torque converter bolts and pull the valve covers to see if a valve is stuck open possibly hitting a piston.
When a car doesn't have body damage and it is stopped being used it is often due to a major drivetrain defect.
First,
Second,
Minor update, road block.
Changed cap and rotor, plugs, wires, coil, resistor or condenser, oil and oil filter (was a rubber drain plug). Added fresh battery. Disconnected coil wire and tried to turn over. Nothing really happened. Getting power as radio started buzzing. Made sure I was in park and tried a couple more times. Heard a slight click or drag like starter may have tried to engage, but didn't. No more sounds after that one time. Connects at battery seem fine. I'm terrible with electrical. What should I do to locate bad connection or problem?
Also; I figured I'd try and change the fuel filter. It's a rigid line from filter to pump. Loosened line at pump, but could not loosen filter side for anything. But was rolled over before I attempted. It's likely worse now. Any tricks Im missing here? Tried holding backup on larger nut or fitting that houses fuel filter but that didn't work. Should I cut the rigid line and remove whole filter housing? I think that might allow me to get a little more torque on it.... should I go get some vise grips and a hammer and just hope for the best?
Get penetrating oil between the nut and the tube. Use a1" wrench to prevent the nut from moving, tightly clamp vise grips on the nut. Hold the 1" wrench and strike the vise grips in the loosening direction. Pay close attention to the parts in the nut, a filter and how it is oriented, a spring and a gasket on the nut. The filter and the gasket should be replaced, the spring may be reused.
Soooo. Just a general question. I bought a new/ reman starter and went to bolt it in but noticed that the original support bracket didn't seem to have a location for the strap/ support bolt. Upon closer inspection of the new starter I've found what looks like a plug where the bolt hole should be. Almost looks like it was driven in or screwed in and then cut off. I can't seem to o grab it very good with vice grips. What are my options. I'm sure I could bolt the starter to the block without the support strap, but I'm also sure Oldsmobile put it there for a reason. Any help is appreciated. Haven't messed with car in a while been busy and it's been raining.
Just to make sure you didn't miss the point made by rocketraider, those do look like police car wheels. If you decide you want to replace them don't throw them away! You'd need to verify the code stamped into them, but if they are police car wheels to the right person you can sell them for a good price!
