Milling heads
Old Oct 4, 2018 | 10:17 PM
redbaron442455's Avatar
Milling heads
Does anyone know what is the most that can be milled off a set of 68 455 big valve C heads?
I'm hoping to be able to bring it down to 70cc currently 85cc.
thanks,
Old Oct 6, 2018 | 06:41 AM
OLDSter Ralph's Avatar
I believe .005" per cc. 15 cc X .005" = .075" material removal.
Old Oct 6, 2018 | 08:31 AM
Charlie Jones's Avatar
Phantom Phixer
If you have your heads milled that much , make sure the machinist mills the proper amount off the intake ports .
Otherwise your intake manifold isn't going to fit .
Old Oct 6, 2018 | 01:36 PM
great thanks guys!
just curious whats the most you have ever heard of being safely milled off olds heads?
Old Oct 6, 2018 | 02:41 PM
Qwik71442's Avatar
Full-time Taxpayer
Originally Posted by redbaron442455
great thanks guys!
FWIW-I have personally gone from 81 to 84cc’s on several sets of C’s down to 72cc with no issues.
Old Jan 2, 2019 | 08:12 PM
73aussie455's Avatar
Acceleratii maxim rapidus
Couple of quick questions here please,
Were you using the stock hydraulic flat lifters in that engine?
Did you have to buy shortened push rods with that much milled off the heads? or did the stock length ones cope ok?
How much needs to be milled off the intake if you mill .012" - .015" off the heads? is there a formula to work this out?
Do you mill the intake side of the heads or the intake manifold flange?
I'm going to do just as the OP has suggested, so I'm keen for any info, thanks.
Old Jan 2, 2019 | 09:45 PM
Go to www.wallaceracing.com Lots of calculaters
Old Jan 3, 2019 | 10:39 AM
Lonnies Performance's Avatar
If i remember correctly, milling .006" off yields approx 1 cc reduction in volume.
Chuxter
Apr 29, 2014 04:54 AM
smietana
Sep 14, 2013 06:14 AM
Olds_71_442
Dec 4, 2012 10:25 AM
ksmitty
Jun 30, 2011 10:41 AM
Young Man
Dec 30, 2010 01:40 PM
