Melling high volume oil pump cover gasket?
Old Nov 24, 2022 | 01:52 PM
BondAR's Avatar
I took apart my melling high volume oil pump (m22fhv) for cleaning and inspection and noticed there wasn't a gasket on the cover. I see that there's a cover gasket included in the Mahle gasket set I have, but is it necessary? I had 60+ psi cold and 25 psi hot at idle without the gasket. Happy thanksgiving!
Old Nov 24, 2022 | 06:54 PM
VC455's Avatar
Barely Registered
If you use the gasket, it will increase clearance between the rotors and the cover.
There will be an internal oil leak that you didn't have before and your pressure will drop.
Old Nov 24, 2022 | 09:51 PM
BondAR's Avatar
Thanks for the explanation, it makes sense.
Old Nov 25, 2022 | 04:41 AM
cutlassefi's Avatar
The gasket is for std volume pumps.
Al2011
Aug 27, 2025 08:30 PM
garage goat 67
Nov 8, 2016 08:48 AM
Macadoo
Nov 28, 2013 11:10 AM
JOHNNYOLDS442
Jan 2, 2013 09:41 AM
jdiggitydogg
Feb 15, 2012 11:21 AM
