Mechanical Water Temp Gauge
Old Nov 7, 2007 | 05:57 AM
KQQLCAT's Avatar
I am trying to install a water temp gauge in my 61 394 and there appears to only be one spot to put it. I would like to keep the original temp sensor in. Has anyone got any ideas? I don't want it to look stupid. They must make a "T" fitting that allows you to do this.
Pat
61 Olds 2dr sedan
Old Nov 7, 2007 | 06:27 AM
442Harv's Avatar
Doesen't it use just regular pipe threads? If so, you should be able to buy a T and make it work.May stick out to far, and be in the way off something, or look funny?
Old Nov 7, 2007 | 07:58 AM
KQQLCAT's Avatar
Regular 3/4 pipe thread. I can find pipe fittings that will work but the look Mickey Mouse. The instructions on the Summit gauges show an adapter but I can't find one.
Old Nov 7, 2007 | 12:49 PM
Pat
61 Olds 2dr sedan
A "T" fitting will NOT work. Unlike an oil pressure sender, the temp sender must be in the flowing coolant. A "T" fitting will be stagnation point and will not be representative of the actual coolant temperature.
Old Nov 7, 2007 | 01:27 PM
Oldsguy's Avatar
Past Administrator
Would there be some un-used bungs in the front water crossover that he could use? I am not familiar with the 394 manifold but can remember that there are some on 455s depending on how many additional "valves and/or sensors" are or are not used.
Old Nov 7, 2007 | 05:18 PM
Modern Motoring's Avatar
there is a petcock on the right hand side of the block. You might be able to adapt something to that hole.
Old Nov 8, 2007 | 01:10 PM
I suggest you install the new coolant temp sensor in the spot where your old one is at. If you want to keep the functionality of your HOT / COLD dummy light then all you have to do is go to Radio Shak and get a simple logic circuit. You would need a circuit to apply ground or 12V (whichever was switched by your old sensor) to your original temperature lights based on the voltage of the new coolant temp sensor. It sounds complicated but you should be able to find something like that at Radio Shak or on the internet.
Old Nov 8, 2007 | 04:48 PM
Go back and read the title of this thread. The aftermarket temp gauge is a MECHANICAL gauge, not an electric one. Not gonna find a lot of help at Radio Shack...
atkinsom
Oct 1, 2013 01:41 PM
54oldz
Jun 20, 2012 07:13 PM
Emreozd
Feb 19, 2012 06:27 AM
olds88royalvert
Jun 11, 2011 04:29 PM
Sam Barrett
May 26, 2009 11:27 AM
