maybe timing problem??
Old Feb 4, 2013 | 09:06 AM
transam79's Avatar
i have a olds 455 in my trans am i pulled it out to paint it put some new chrome on it new oil pan ... anyway, i put it back in never took the distributor out never moved it nothing,,, all i did was take the 800 double pumper off cuz it was leaking the base plate was cracked and what not anyway,,, i put a 670 street avenger on just to let the motor run but damn the motor is running the **** its backfiring through the carb, the plugs are telling me its running rich they are dry black and sooty, the plug wires are all in the right spot and i never pulled the distributor it ran pretty good be4 i pulled it? any ideas guys? i did pull the one head to see if it was bored but i mean i put it back on right and torqued the rocker arm bolts back to 25 ft lbs
Old Feb 4, 2013 | 09:07 AM
Guess #1: Plug wires.
Old Feb 4, 2013 | 09:09 AM
transam79's Avatar
i got a firing diagram offline made sure i routed them right i triple checked them they are routed right
Old Feb 4, 2013 | 09:10 AM
Right for a distributor that turns counter-clockwise?
Old Feb 4, 2013 | 09:11 AM
transam79's Avatar
yes sir that was the diagram i got offline
Old Feb 4, 2013 | 09:13 AM
Hmmmm... Okay.
And it's not 180° out of sync.? (remember TDC for #1 can be compression for #1 or #7)
Old Feb 4, 2013 | 09:15 AM
And you're sure that the new carb doesn't have a stuck float or needle valve, right?
transam79's Avatar
i don't believe so i mean i never moved it when i pulled the motor and it was fine be4 i pulled it i was thinking it has more to do with the small carb i put on but im not sure....how do i tell if its 180 out? right now its pointing at number one on tdc compression but there was a few diff diagrams that showed the number one was towards the back of the distributor then the one i had that shows the number one plug wire is in front of the distributor
Old Feb 4, 2013 | 09:16 AM
transam79's Avatar
and yes positive on the no stuck float or needle valve the carbs not even 3 months old
Old Feb 4, 2013 | 09:17 AM
Wherever the #1 wire is connected, the rotor should point to that terminal when #1 is at TDC on its compression stroke.
Old Feb 4, 2013 | 09:18 AM
We've had examples of new carbs with stuck floats on this board, so be careful.
transam79's Avatar
ya thats how it is its pointing at number one tdc compression i haven't timed it yet but i don't see how it coulda got out of time if i never pulled the distributor
Old Feb 4, 2013 | 09:19 AM
transam79's Avatar
i have had the float bowls apart be4 to change jets put bigger ones in and it made it worse it would just choke its self out with to much fuel
Old Feb 4, 2013 | 09:20 AM
I agree, it shouldn't have.
Any chance you've got a bad ignition component - module, pickup, etc.?
This is one of those problems where you're going to have to go very slowly, step by step, and re-check everything, until you find the one obvious problem.
Old Feb 4, 2013 | 09:25 AM
transam79's Avatar
idk unless the coil went bad on it
Old Feb 4, 2013 | 10:42 AM
hullinger's Avatar
I'm thinking the same as MDchanic as it's something ignition related. Something simple like a cracked or worn distributor cap/rotor, frayed or shorting coil wires, or malfunctioning electronic ignition.
Old Feb 4, 2013 | 11:20 AM
Rickman48's Avatar
Might the motor have a larger cam, not pulling enough vacuum for that carb??
jpc647
Jun 10, 2013 11:48 AM
ihengineer76
Jul 28, 2012 04:09 PM
Col Wickham
Sep 20, 2010 04:26 AM
442scotty
May 13, 2009 05:42 PM
Margie's68
May 26, 2008 04:14 PM
