maybe timing problem??
i have a olds 455 in my trans am i pulled it out to paint it put some new chrome on it new oil pan ... anyway, i put it back in never took the distributor out never moved it nothing,,, all i did was take the 800 double pumper off cuz it was leaking the base plate was cracked and what not anyway,,, i put a 670 street avenger on just to let the motor run but damn the motor is running the **** its backfiring through the carb, the plugs are telling me its running rich they are dry black and sooty, the plug wires are all in the right spot and i never pulled the distributor it ran pretty good be4 i pulled it? any ideas guys? i did pull the one head to see if it was bored but i mean i put it back on right and torqued the rocker arm bolts back to 25 ft lbs
i don't believe so i mean i never moved it when i pulled the motor and it was fine be4 i pulled it i was thinking it has more to do with the small carb i put on but im not sure....how do i tell if its 180 out? right now its pointing at number one on tdc compression but there was a few diff diagrams that showed the number one was towards the back of the distributor then the one i had that shows the number one plug wire is in front of the distributor
Any chance you've got a bad ignition component - module, pickup, etc.?
This is one of those problems where you're going to have to go very slowly, step by step, and re-check everything, until you find the one obvious problem.
I'm thinking the same as MDchanic as it's something ignition related. Something simple like a cracked or worn distributor cap/rotor, frayed or shorting coil wires, or malfunctioning electronic ignition.
