The MAW's got me..........
Old Nov 11, 2013 | 12:11 PM
RandyS's Avatar
I pulled the motor out of my L69 so I could detail the engine bay and paint the motor, as one of the prior owners had painted it RED.....OMG. Once I had it on the stand, I thought MAW pull the pan and check the bearings...... not a pretty sight. I have attached a pic of the rear main bearing and #7 rod bearing. Lots of scoring and some pitting. The motor ran great prior to pulling, and had decent Oil Pressure (45-50 cold, 30-40 hot). The journals have some scoring as well. The motor has been open at some time prior as the rod caps have the numbers peened on them, and the crank has .010 painted on the 1st counterweight. Time for new bearings?
(Then the MAW's really begin.............Arghhhhhhhh)
Old Nov 11, 2013 | 01:25 PM
pogo69's Avatar
morgan
same here brother...took my engine out to do a cleaning/painting and was surprised at what i found with bearings...i guess its a good thing i did, it just reinforces the ''never assume anything'' when dealing with an engine untill you actually look at it
Old Nov 11, 2013 | 01:55 PM
Professur's Avatar
Take a copper penny and rub it across the journals. if it leaves a copper trace ... you need more than just bearings.
Old Nov 11, 2013 | 03:02 PM
2blu442's Avatar
Might As Well... but then you'll know you've got many miles ahead of you with a sound engine!
John
Old Nov 11, 2013 | 03:51 PM
Octania's Avatar
That's gwan be one expensive paint job!
Old Nov 12, 2013 | 07:57 AM
Lars's Avatar
I betcha it ran great and didn't knock. and probably would stayed that way. the rule of thumb should be "don't open a motor up unless your ready to spend 1000 bucks"
my maw issues
http://realoldspower.prophpbb.com/topic2682.html
don't tell anybody over on ROP, but i'm going to do a-little test run on bearings, I going to assume the bearings got schorched on initial start up and ran fine for the rest of the time. since the crank only touches the bearings on initial startup "theroryletically" I took 220 sand paper and smoothed out the bearings and i'm going to install them, mains and rods, I'm going to build a test run stand and cold start it for about 2 months and rev the **** out of it. I wont be out any money unless I spin a bearing. I want to know how tuff bearings are.
Troys Toy 70
Jul 18, 2015 09:06 PM
Allan R
May 30, 2014 10:39 AM
kitfoxdave
Jun 2, 2012 08:34 AM
Magna86
May 21, 2012 07:45 AM
sicky olds
Brakes/Hydraulic Systems
16
Apr 10, 2012 12:03 PM
