Möwe Pistons and rings
Old Sep 9, 2025 | 01:06 PM
Jelonek's Avatar
Jelonek
Hallo Everybody
we try to rebuilt engine from 1966 Toronado with 425 super Rocket Engine
I have a, aktuelle Pistonswith 0,020 oversized and I Need a really, Good Pistons for this and wie have this at the picture.
everything is ok but wie cant After put in free Pistons move the engine
gap , masurment etc. everything wie Check 5x
my question is:
are this the Right Pistons for this?
is that normal ?
do you have any
idea???
best greeting Wojtek
Old Sep 9, 2025 | 04:24 PM
OLDSter Ralph's Avatar
What is on the piston box ? How much piston clearance do you have ?
Old Sep 9, 2025 | 04:27 PM
cutlassefi's Avatar
Was the block bored .020 for those pistons?
Old Sep 9, 2025 | 04:29 PM
BillK's Avatar
The rings are file fit rings. Did you file them to get the proper end gaps ? If you do not have the tools to file fit the rings just buy a "normal" (non file fit) set of .020" oversize rings.
Old Sep 9, 2025 | 11:09 PM
Jelonek's Avatar
Jelonek
The block is bought to 0.02 and the rings would be made fit for this setting it seems to be everything okay but I have the feeling there was no so many place like a normal
Old Sep 10, 2025 | 07:52 AM
BillK's Avatar
J,
The rings in your picture are 4.145 +5 The "+5" means they are made .005" larger so you have to file fit them to the individual cylinders. If you installed the rings without doing anything to them I am surprised you even got them to go into the cylinder.
Old Sep 22, 2025 | 10:16 AM
Jelonek's Avatar
Jelonek
So, have ever Interessent Phänomenon
Everything is prepared and put together, crankshaft with Baring and Pistons Without Rings I can turn it all with Two Fingers, without Problems and very Smooth
But if I put the Pistons with Rings (only 1-3 pistons with rings ) it is not possible to turn the Engine, this is very very Heavy tight
I have no idea why. all System Works very good Without der Pistons the block is bored to the Distance of 0,020 , the rings are filed fit for this system etc.
any ideas ??
Thanks for your help!!!
Old Sep 22, 2025 | 01:02 PM
cutlassefi's Avatar
If the rings were filed correctly, then the next thing to check is their radial depth. In other words, the depth of the rings are normally about .020-.040 less than the depth of the ring groove. I’d check that next.
jimmy361713
Apr 14, 2024 10:35 PM
442blue
Apr 18, 2023 04:29 PM
Tgbunch
Aug 22, 2022 09:56 PM
Flye
Nov 3, 2013 02:58 AM
defiant1
Sep 3, 2011 07:50 PM
