C head identification
Old Nov 22, 2017 | 03:49 PM
Platinum69's Avatar
Hi, how can i tell if the C heads on a 68/69 are big valve or not, still on engine? Thanks
Old Nov 22, 2017 | 05:04 PM
I remember hearing or reading somewhere the big valve heads had a X stamped on the machi ed rocker arm stand
Old Nov 22, 2017 | 08:03 PM
2blu442's Avatar
Sorry, you'd have to pull the heads and measure the valves. They used the same castings and just cut out the seat for the valve size desired. The 1967 had an application code stamped in one head. But 1968 and newer didn't. If you knew for a fact they were original... and you knew the engine was a factory 442 or Toronado engine they would be big valves. But for an engine that's 50 years old who knows what's been done to it over the years.
John
Old Nov 23, 2017 | 05:53 AM
Originally Posted by 2blu442
sorry, you'd have to pull the heads and measure the valves.
^^^this!
Old Nov 4, 2019 | 06:49 AM
Three504spd's Avatar
Are there any identifiers on the heads to indicate correct year or model?
-Christopher
Old Nov 4, 2019 | 06:55 AM
-Christopher
Not really.
If the heads came off of a 1967 motor, there will be an engine unit number stamped on the front of the passenger side head. This will tell you the original application - of that one head, anyway. Other than that, there are no external distinctions, and definitely none on 1968-69 heads.
Old Sep 25, 2025 | 11:57 AM
mpowell's Avatar
Old thread I know but I have been scouring the interwebs for this very thing. I just confirmed this on my extra C Heads with A.I.R. They both have an X stamped on rocker arm stand like Matt mentioned over # 1- and 8-cylinders. That being said, I have yet to actually measure the intake valves to be 2.072 so may still be a myth? I have read about the X in a few places now so am fairly confident it is a tell for big valve heads.
adis
Nov 30, 2021 05:12 AM
Al2011
Apr 18, 2014 11:14 AM
MN71W30
Feb 10, 2009 12:17 PM
74omega
Jun 15, 2008 06:28 PM
The_Jeremiah
Sep 26, 2007 04:29 PM
